Question about Kenmore Dryers
What is a kenomore dryer P/N 3387134 - Kenmore Dryers
What number thermal fuse and thermostat will work on kenmore elite model 11o 23032 dryer
thermal fuse 3390719
Thermal cut off and high limit kit 279816
Operating thermostat 3387134
Jan 22, 2017 | Kenmore Dryers
Why is my kenomore electric dryer not getting hot
Either the heating element is gone or the heat safety sensor(s) is/are defective is the most likely answer
Sep 18, 2014 | Kenmore 110. 1W100511769 Washing Machine...
Dryer wont start
Part# 3392519 is most likely suspect as needing replacement. Located behind the main panel in the back of the dryer and mounted to the blower housing, long white/slightly oval. These thermostats can burn out for various reasons, it's best to have the home venting system checked by an accredited company to ensure it's properly functioning. Additionally Part# 3387134 should be replaced too.
Apr 11, 2014 | Whirlpool Dryers
Kemore dryer model110.67522600, checked continuity on heating element,OK, Thermal fuse OK,cutoff-tml ? Thermostat #3977767 no continuity.Thermostat #3387134 ?
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Sep 16, 2010 | Kenmore Dryers
Hi i replaced the thermal fuse in my kenmore dryer, started it up and it blew less than five minutes, what`s the problem any takers?
I would check your venting and also replace your cycle thermostat (4 wire therm) mounted right next to the thermal fuse. If you have a clear vent and new cycle therm this will take care of the problem. part number on the cycle therm is 3387134
Good luck _MJ_
Feb 06, 2010 | Kenmore Dryers
Dryer wont start, drum hard to turn-revised
get a new drumm it might be bent if your putting stuff that weight alot in your dryer if its making a skeeking rusing soung get a new drum about 400 dollers
Dec 21, 2008 | Dryers
Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
May 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
18 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
