How replace rear deck on a 32 foot marinette boat
Where are the drain plugs situated on a T Cat boat
has to be out on the rear hull area
below water line or deck platform
upgrade hull with
aftermarket stainless steel or brass systems
wise to have a bilge pump
and carry bailing buckets
9f16875a-8021-465a-81f2-8f6b06be53e4.jpgindex-cvxygyvu0vydc25j522ljeey-4-2_0.jpgst-cvxygyvu0vydc25j522ljeey-4-3.jpg
Mar 31, 2017 | Boating
I need to know the beam on a 1972 Marinette 28 ft cabin cruiser. Thank you.
Might be good to post your question on a section that has something to do with boats.
Nov 16, 2016 | Cars & Trucks
Tracker 215 Tahoe Deck Boat 2009
check near the fuel tnks at the rear and bottom of hull.
Jul 13, 2014 | Boating
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
Anchor light wireing for hurrcane deck boat
Check the electrical connections, bulb and switch.
Jun 26, 2013 | Westland Godfrey Pontoons & Deck Boats...
I have a 2006 Lowe 160 Stinger Aluminum boat. I am up grading from PD 40# to PD V2 55# which has a heavier lower unit ...Problem is this unit mounts closer to the front edge of my boat and after 6 years of...
Hey 217,
Get a sheet of 3/16" aluminum plate that is at least twice as wide as your trolling motor mount and at least 12" longer than the mount. Secure the plate to the current deck.. align the front edge flush.
You might want to radius the edges of the plate and secure it with rounded head sheet metal screws.. This will make the mount much stronger and last!!
Jul 06, 2017 | Minn Kota Powerdrive V2 Bow Mount Trolling...
What steps are required to replace broken deck impact absorber. What items must be removed to access the area of the deck impact absorber. Where does the deck felt washer go in relation to the deck load...
Depending if this is a L7 You must first go to the end of unit using 9/16" socket counterclockwise pull the bolts off now when doing this couter the rotation that is took for the bolts to come off write it down so when you are ready adjust tension you have a reference . Then proceed to remove the end plates (Phillips screws). Then where the foot plate is slide the plastic cover off and you will see screws holding the foot plate remove them and the plate will come off. Go back to the end and remove rear roller , now you will see first the felt washer these used to dampen noise when you are walking or running.Now you will be able to lift and slide out the broken deck and you will see the deck load washer and impact absorbers To replace them you can use an adjustable end wrench go under each absorber loosen lock nut. Also on the safe side I would inspect the running belt to see if the deck damaged it. Reverse disassembly procedure and start unit increase speed around 3.0 mph and adj belt tension 1/4" turn ( clock wise) at a time until belt is not slipping and to center belt.
Apr 15, 2010 | Landice Pro Sport Trainer Treadmill
Should the fron of deck be higher than the rear of
no you can adjust it too level must read manual ? has rods for adjustment
Aug 31, 2009 | Garden
Outboard problem
Check your prop...probably slightly bent and only is noticeable at higher rpms.
May 20, 2009 | 2008 Mercury Mariner
Lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Mar 29, 2009 | Lowrance X135 Power Pro Sonar Without...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
