Question about Alesis Music
Alesis Qs6.2 / Re-initialized and now no Sound on any Bank?
No voices in user bank! Re-initialized and now no sound from any bank! Alesis Qs6.2 keyboard
4 Suggested Answers
  • 5603 Answers
SOURCE: Only the piano sound works on my D-20.
We can't possibly guess at what brand a D20 might be,,, HOWEVER let's guess that it is some kind of synth.
I would "guess" that you problem might be that the ionternal memory battery has depleted and the settings and sounds are all lost.
First thing would to be replace the battery. Next the settings need to be restored. SOME instruments have a sequence of buttons to hold while powering on to restore factory settings. Others require you to load data from an external source via MIDI or other method.
Posted on Feb 13, 2010
  • 5603 Answers
SOURCE: piano does not work no sound can be heard power
I could not find the schematic for this, but other Casio units use a common voltage regulator amplifier chip to drive the speaker... I would firsst check that leads to the speaker have not become disconnected.
Posted on Jul 19, 2011
  • 5603 Answers
SOURCE: I have my sound banks
Sound banks does not define what keyboard you might have... HOWEVER... THINGS TO CHECK: Check if the bass MIGHT have a transpose set by mistake. Also check if pitch bend might be active... some keyboards can use a pitchbend pedal... We can't guess what brand or model keyboard you have. Batteries are NOT anything that would cause this. Remember that on a keyboard there is a LIMIT to the number of sound generators that are available and you can run out of polyphony with mass layering. The last thing might be any "effects" you have activated. It sounds like you can split this keyboard so separate transpose MAY be possible that low end is transposed while upper is not...
Posted on Sep 07, 2011
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
No sound on my SY77 yamaha synthesizer
1) Turn the power on.
2) While pressing the [VOICE] button, press and hold the [BANK D] button, then the [8] button. The SY77 will run the INITIAL TEST routine and display the Test Program Menu.
3) Press the [COPY] button. The SY77 will execute Test 48 'Factory Settings', automatically exit the test mode, and then return to play mode.
Mar 31, 2013 | Music
Casio keyboard 465 sound tone bank ct638 manual
I have a 465 sound Tone Bank Casio piano that was dropped and now it doesn't work. I'm not sure what the problem is.
Jan 16, 2012 | Casio Music
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
Drum sound distorted
Try a factory reset:
alesissr16logo53x41.jpgrmidialesissr16logo53x41.gif Performing a 'Reset' on your Sr16 will will 'clear' it's memory and re-initialize all of it's parameters to the original factory settings. This implies that:
  • All of your User Patterns will be erased.
  • All Songs will be erased.
  • All drum assignments you have made will be erased.
  • None of the above actions should be an issue to you as:
  • It is assumed that at some point you have Download And Save A Copy Of The Sr16's Current State.
  • It is assumed that at some point you have Export any 'User' Patterns you may have programed into your Sr16 and imported them into your _rMidi installation.
  • It is assumed that at some point you have Export any 'User' Kits you may have programed into your Sr16 and imported them into your _rMidi installation.
  • Perform The Reset
    To perform a 'Reset' on your Sr16:
  • Turn the pwer off and wait a few seconds.
  • Press and hold the PLAY and ERASE buttons while turning in the power.
  • Continue holding down these buttons for at least three seconds after turning on the power.
  • If this doesn't fix it, check power adapter. If that is OK then service is required
    Jun 06, 2010 | Alesis Sr 16 Stereo Drum Machine
    I can't get my dm5 drum set to play,I have reinitialized the sound module and it does not make a sound.
    DO the initialize again as on this site:
    http://www.hartdynamics.com/support/alesis.html
    and follow the directions about setting each pad volume and the dynamic =1
    Feb 05, 2010 | Alesis Sr 16 Stereo Drum Machine
    I have a Casio WK3500 keyboard. How can I reproduce the sound of a Wurlitzer organ?
    Try voice 9 in the bank 96. That is for a theater organ type sound. You would need decent sound system to amplify this and to sound anywhere near decent.
    Aug 14, 2009 | Music
    I would like to find how to store styles and sounds onto pa 800 without losing the ones all ready there
    most korgs have a user bank. bank a b c and d then user.
    you can store them there.
    Jul 08, 2009 | Korg Pa800 Synthesizer
    Music Logo
    Top Alesis Music Experts
    drivealot
    Lawrence Oravetz
    Robert Graf
    Are you an Alesis Music Expert? Answer questions, earn points and help others
