Question about Kenwood KDCX395 In Dash Receivers
Why won't my kenwood turn on? - Kenwood KDCX395 In Dash Receivers
Tried to install a Kenwood stereo in my 2003 Chevy trailblazer and I removed the dash components but now my suv won’t even turn over . Why won’t my suv start now
You have know idea what your messing with , Leave it to a qualified repair shop . One that knows about class two serial data networks an how they work . Case 4 Data Bus Issues
Jan 18, 2018 | Cars & Trucks
Kenwood 6.1 dvd screen won't turn on, but reset
It appears that you may have battery power but, no accessory power. Check you radio fuse in the vehicle and, behind the radio.
Feb 06, 2013 | Car Audio & Video
My kenwood kdu-u7053bt won't keep it's memeroy. Keep going to demo mode when I turn the car on.
go back to the stereo shop and make sure they connected the memory wire on the unit to a constant 12v source
Feb 03, 2013 | Kenwood Car Audio & Video
The kenwood KDC-MP333 in my truck is connected to a set of kenwood speakers. But when I turn it on they won't work the stereo still shows the display but when I turn the stereo on it makes a sort of...
Disconnect the speakers and try it with another speaker or speakers not in the truck. If it works, the speakers or the wires to them are messed up. If it doesn't you probably damaged the output capacitor in the radio by turning it on without speakers attached. Realize that the speakers are part of the radio circuit and act as resistance. Without them, there is no resistance and it puts a strain on the radio.
Jan 02, 2013 | Car Audio & Video
Kenwood prospero km262 stopped working
In my case, capacitor C1: 470nF (on the circuit board) proved to be the cause. It measured only half its normal value. It's part of a voltage divider used in place of a transformer. Replacing it solved the problem.
Came already across the same problem in another circuit.
Dec 02, 2012 | Kenwood KM800 Major Classic Stand Mixer
My Kenwood A-51 amplfier won't play music when connected to speakers.
http://www.agtannenbaum.com/k_cat.htm#KENWOOD manual here..........meder's tv service
Sep 10, 2012 | Kenwood Audio Players & Recorders
The back light won't turn on and the volume is turned all the way up but the buttons won't work for me to turn it down. I had to take the whole thing out
Assuming your deck is a kdc 516s the flexible cable that goes from the face to the main motherboard is probably bad. If you are not good at desoldering and soldering. , I would suggest you have it replaced by a professional.
May 06, 2012 | Kenwood KDC-516S CD Player
My Pioneer DEH-P4200UB Won't power up in my 97 mustang gt. The car recently had a kenwood deck that we took out. we are still using the kenwoods wires. Help us lol
Hi
Please verify voltage at the constant (Yellow) wire With the ignition OFF
Then Turn the Key to ACC and verify voltage on the RED wire.
Double check the ground to chassis metal.
The radio should power on at this point if both power wires show 10-14.4VDC
If not - your radio needs repair.
Thanks!
Nov 02, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
We purchased a brand new Kenwood Food processesor FP190 series. Plugged it in socket to operate, but it does not turn on. Any advice? Thank you Homa
This is clearly a manufacture defect, there can be any number of reasons why it won't work, defective on/off switch, motor, or an open fuse. the only option is to return the item and have them exchange it.
Jun 19, 2011 | Kenwood Microwave Ovens
Can't get my amp to turn on
You need to confirm that you have sufficient B+ and remote turn-on voltage.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KDCX395 In Dash Receivers Logo
35 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
