Viewsonic Pjd5134 goes off after 5 mins red lamp light comes on 4 months old
BingoDabbers
  • 102 Answers
SOURCE: viewsonic pj 800 projector
Yes.
Posted on Oct 06, 2007
SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Posted on Jan 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
dhecom
  • 233 Answers
SOURCE: 1-Projector is in standby, so I hit the power
I think it's capacitor issue on the power supply board. open it, look for power supply board and fine bloated capacitor and replace it.
Posted on Feb 15, 2010
  • 16 Answers
SOURCE: Samsung DLS not working(with new lamp)
The grinding sound is most likely the color wheel. The lamp will not fire up if the computer senses the color wheel is not in motion or turning too slowly. It does this to protect the color wheel from being burned.
Something else you need to realize is the fans sometimes make some noise(especially the fan at the rear of the DMD Board).
The Ballast does not go bad that often and is misdiagnosed more times than it actually needs to be replaced. Sometimes the DMD Board is defective and won't send the color wheel the signal to start which in turn doesn't let the lamp turn on. I have read this misdiagnosed as a bad lamp, ballast, and color wheel multiple times. I currently have two of these in my shop at the moment and they were both verified by swapping known good DMD Boards.
There is some very good information available on this site but many times it isn't that simple of a repair. You need to get all the information and verify before buying parts. Most of the time it will pay for someone to have a reputable shop do a repair rather than buy parts that are not needed. I have had three people buy lamps in the last week, and two replace capacitors, only to give me a call and fix the problem correctly. All of these people got the repair tips from the internet.
Posted on May 07, 2010
How do I open up?
NOPE U NEED TO REPLACE COLOR WHEEL
Oct 07, 2015 | ViewSonic PJD5134 DLP Projector
ViewSonic PJD5132 machine turns on but there is no picture. Automatically turns of with a red light on the lamp button after about 2-3 minutes.
Sounds like the lamp is bad. If you take it out, look to see if it is broken or if there is a bubble on the lamp. If either of these is the case, buy a new lamp. If it's not the lamp, it's the igniter and if it's only 3-4 months, it's still under warranty and that should be fixed.
Feb 17, 2015 | ViewSonic Office Equipment & Supplies
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
I turn on my Viewsonic PJD6251 but the lamp does not come on, and after a few seconds I get 2 red lights TEMP and LAMP. It is new, only 2 weeks I barely used. Good care.
sounds like a bad bulb
projectors get a resistance reading from the bulb and if it doesnt get right value it will give you the double red lights
only other thing it could be is if the fans in projector are not turning on
call viewsonic and tell them issue and make them resolve issue
or
if unit is only 2 weeks old bring it back to store and get replacement or call viewsonic and get them to send you replacement unit - it is too new to mess with it yourself and take chance on voiding warranty
Mar 24, 2011 | ViewSonic PJD6251 Projector
Ok i been searching for a solution and i have gotton nothing....so i thought i would post my problem, i hope it can be answered. i have a viewsonic monitor and almost ever since i'v had this computer, the...
1) To unlock the monitor: http://www.fixya.com/support/r4554177-viewsonic_monitor_lock_unlock
2) I am not sure about the red light, are you taking about the power light or you are getting red tinting cast on the screen.
3) The monitor is old will more likely to have problem in the power supply by now due to bad caps and it can make the monitor act strangely. I am not sure what you mena by loos power cable.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
I would not suggest you to try to take it apart since there are high voltages inside that can kill you.
Sep 27, 2010 | ViewSonic VA721 17" LCD Monitor
I have a Viewsonic VX2245wm or VS11349, Works and then it goes black for 2 to 4 sec then runs for 10 to 15 min and goes black
Look at the power supply section for bad caps first, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, it can also be caused by bad inverter circuits or bad lamps.
Feb 20, 2010 | ViewSonic VX2245WM LCD Monitor
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
