Question about DeLonghi PAC C120 12000 BTU Portable Air Conditioner
Why red light flashing on delonghi pac cn120e and will not turn on.
SOURCE: FE Light
You need drain the water and then function normally.
Posted on Oct 02, 2007
jfpogie
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
SOURCE: delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Posted on Sep 06, 2008
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
SOURCE: Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Posted on Sep 19, 2008
Delonghi Pinguino PAC cn120e
Contact Delonghi to request the wiring diagram.
Mar 01, 2018 | Refrigerators
I have a Delonghi room Unit PAC CN120E that stop cooling I have had it 5 years,
Take it apart take it outside and wash both coils with a water hose.
Oct 03, 2015 | DeLonghi Heating & Cooling
How do I remove the interior packing styrofoam from PAC CN120E
that IS NOT PACKING FOAM!!!that is used in air conditioners nowto be energy efficient,its cheaper than plastic
Jun 06, 2015 | DeLonghi PAC-C120 12,000 BTU Home Electric...
Pinguino Pac cn120e. Where do black and white wires go?
Can u upload more new pictures of it form different angle
May 20, 2015 | DeLonghi Heating & Cooling
How do you remove back of delonghi pac cn120e ac
Remove screw s from back around unit and the back tilts and lifts off.. not easily i might add. I have a question posted as to where do plug wires attach to inside unit. Replacing plugc and not sure where black and white connect to. Can you help me..no one seems to have had theirs apart. I can send a pic of screws location if you need. if you can msg me back . Thanks ahead
May 13, 2015 | DeLonghi Heating & Cooling
PAC cn120e how often do you drain
Tough to answer. Depends on humidity and how cold room is set. Consider setting it up and run tubing to lower pan so it will keep running and not shut off when full.
For example I used mine 8 hrs daily for 2 summers in a very dry room and never had to drain it.
Jun 30, 2014 | DeLonghi Heating & Cooling
My PAC CN120E was working fine until the outlet that is above it started to smoke. I plugged it into another outlet and red lights came on but quickly disappeared. Can you advise if the unit is blown out,...
I cannot tell from which country or area of the world you are, but in the USA, your 12,000 btu a/c unit would take a special plug and electrical circuit in many homes or apartment, because it is so large.
Today, most circuits are protected with a 15 amp circuit breaker, which can usually handle only a 5,000. or 6,000 btu unit. The next size up it often a 7,500 unit, and that is a lot for a 15 amp circuit .Some older homes have a 20 amp circuit breaker, which can handle up to a 8,000 btu a/c.
Before you start a fire in your house, have an electrician check all this, and see what is going on.
One reason I am talking about such small a/c units it that usually, household electrical circuits have other loads on them besides the a/c.
Be blessed.
Oct 06, 2013 | DeLonghi PAC C120 12000 BTU Portable Air...
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
FE Light
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC C120 12000 BTU Portable Air Conditioner Logo
1,875 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
