Question about American Standard Heating & Cooling
Compressor not coming on, is there a reset button
Model # 2Tec3f48A10001AA, Serial # 61453JT2V half horse power FL amps 2.70, Volts 200 - 230
    Genius:
  • American Sta... Master
  • 1,363 Answers
Try compressor capacitor.
Posted on Aug 14, 2015
How many Horse power Dei-815/E freezer
Freezers are not measured in horsepower, only mechanical engines. This is the specs, and it is basically a 25 amp freezer, with an additional 7 amps or fans lighting and door heater, both at 250 volts AC. However, running an Amps to HP converter gives 6.971 horsepower.
DEI-815 dual controller with external probe box d
  • DEI-815 dual controller boxed With external probe
    Set Temperature range: -40 to +40
    Tolerance of 1 ° C
    Contact compressor outlet 25 Amp. 250 VAC
    25 Amp Output contact resistances. 250 VAC
    Contact Fans, lighting and perimeter heater 7 Amp. 250 VAC.
    Connection 110- 220 V 50/60 Hz.
    NTC sensors 02 1.5 mt.
Mar 16, 2016 | Cars & Trucks
How much for a new one????need price
Size matters if you use pneumatic tools. The tool calls for a minimum amount of CFM (cubic feet per minute of air) and the compressor should meet the demand.
The electrical characteristics is another issue. Figure a circuit amperage just for the compressor. about 10 amps per horse power at 120 volts and half the amps, 5 amps, for 220 volts.
Buying a new compressor may involve a new electric installation to accommodate the electrical requirements.
You can pick up a new basic 120V air compressor for about $75
May 26, 2015 | Air Tools & Compressors
Keeps blowing internal breaker
The unit rated at 3 HP at 115 volts draws 13.8 amps is odd, a HP in watts is 745 and should be about 2200 watts and 19 amps plus a efficiency loss. Odd to see the ratings don't jive with electric theory/formulas.
The compressor should be connected directly to the wall and if using an extension cord, the cord needs to be #12 AWG or larger to avoid line voltage loss and over amping of the motor.
Here is contact and support info: For more information, please call 800/4-MAKITA (800/462-5482) or visit makitatools.com.
My bottom line is, A 115V motor circuit needs 10 amperes per horse power or 30 amp circuit for 3 horse power. Using extension cords calls for upgrade in wire gage of the cord. The advantage of using 230 volts is it cuts the amperes in half and allows use of smaller gage wire. Watts, or volt amperes is the product of volts and amps.
May 18, 2015 | Makita MAC5200 3.0 HP Air Compressor
Whirlpool calupso FL (over fill) flashes....The manual says the washer will beep every 10 seconds and the pump will cycle one half minute on, one half minute off until the over fill switch is reset or the...
Hello & Welcome to FixYa
FL error indicates flood condition and is caused due to any overfill condition that occurs inside the washer. To clear the display you can press and hold the STOP/CANCEL button. Usually this error is caused when overfill switch trips due to excessive water in the tub. You can also try to clean the drain hose and check the water inlet valve. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Model UAKA 030JAZ was working fine. Now, the compressor fan does not come on and neither does the compressor. I don't know how the contactor works but it is not engaging (the spring loaded contacts are...
Hello
You need to complete the 24 volt circut from the themostat to the transformer to get the contactor to pull in.
Check for voltage at the transformer,should be 120 v in 24 volts out.Also there may be a small reset button on the transformer.
Apr 18, 2011 | Ruud UAKA030 Air Conditioner
I need a drain plug for a Clarke Air pancake two horse compressor. Model AC2001 Serial # 1005188 Where can I locate one? Dan
Master tool repair is a good web site to get things like that, they sell a lot of generic parts like that
Dec 29, 2009 | Clarke Power Products Inc AC2001 2HP 4...
HITACHI AIR COMPRESSOR
what type of air compressor you have,since when you maintained it
Sep 23, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Can i see the models from 1983 to 1985,i need a belt so i can use reverse again but i dont now my model or size. my husband died 3 years ago. if i could see some pictures from the 1980's mine has a potatoe...
Your question doesn't give enough detail to properly answer. Do you know if the tiller is a Horse model or a Pony model? Troy Bilt made both models back in the timeframe you noted. The Horse model had tires that required air to inflate. The Pony model likely had hard rubber tires in that era. The Horse models had a reverse disc, no belt. The Pony had a belt.
Once you know which model you have - look for your closest Troy Bilt dealer and see if they can track down the part for you. They might appreciate it if you could provide the serial number - which is located on the pipe connecting the tiller transmission front half to the back half, where the tines are located. It's stamped right into the metal tube on both models.
Jul 17, 2009 | Troy-Bilt Garden
I have double ovens They are not getting hot. The top one is only heating to 175 and the bottom one is not getting very warm either. The red light is not coming on. It took me 4 hours to bake a meat loaf....
I tried to do a search on the model number you provided and couldn't find anhing on the unit. If you have electric ovens then I would suggest resetting the breakers, It's very likely that your unit is being supplied with half voltage (120 volts vs 230 volts) however if your unit is gas then this would be an altogether different matter & I would need the correct model number from the unit itself for a proper diagnosis... Hope this helps... Bill
Jun 06, 2009 | Ovens
Ingersol Rand
20.5 X 1.15 SERVICE FACTOR = 23.58 AMPS. ALMOST ALL COMPRESSORS RUN INTO THE SERVICE FACTOR AMPS. AS LONG AS YOU DONT EXCEED 23.58 YOU SUPPOSIVELY WONT DAMAGE THE MOTOR. MOST COMPRESSORS HAVE A DUTY CYCLE OF COMING ON ONCE EVERY 8-10 MINUTES. IF YOUR COMPRESSOR IS TOO SMALL FOR THE APPLICATION YOU MAY RUN IT TOO MUCH. 20.8 AMPS IS ALOT FOR A 460V COMPRESSOR, MUST BE AT LEAST A 15 HP OR LARGER. IF THE PANEL IS WITHIN 100 FT THEN #10 WIRE SHOULD BE GOOD. HOPE THIS ISNT ONE OF THOSE 3600 RPM MOTOR P.O.S. HOPE THIS HELPS. JODY
Apr 08, 2009 | Air Tools & Compressors
Heating & Cooling Logo
82 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
Pete Norton
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
