Question about Nokia 5310 Cellular Phone
The soft pad keys are not working i can't press un lock and * to open it nor turn it on or off can any one help me it gose off only when i remove the battry and on when i press the start button i removed the memory card but still the same i removed the sim the memory carrd the battry and tried again but still the same i can't even use the pc unless i open the key locker please help me with my nokia 5310 xpress music
  • shweikarsule Jun 23, 2009
    hi, i have fixed my daughter's mobile first i turned it off, removed the sim card left till the next day then turn it on quicly i set it all to factory setting after restarting it hung on while asking to set the day and time so i took the memory card and used my other daugther's mobile to removed the passward
    then put it back again then i used the usb on my pc i tried to backup the phone contacts and setting it worked then i updated it then i restored the backup again and it was working again and my daugther was very happy and praud of me. i have also solved the problem of my hasband's mobile nokia n70 who have posed his problem on fix ya his name is abdulhakim he could not find his pic on the studio so i removed his memory card and put my old one and it worked then i realized the the problem was with his memory card so i formed it and tried to open the studio it worked after a while and slowly started to work again waw i am realy happy that i could help. what do u think
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
Ur phone keypad flap is damaged change it it containes music keys, on/off switch, and keypad. if u satisfied then plz send thanks
Posted on Aug 20, 2009
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
I can not turn my mouse pad back on after it turned its self off Toshiba L20-267
Hi
in most cases if you press the FN+F7 keys together and leave for a couple of seconds then hopefully it will enable the mouse pad
just have a look at the top row of keys to find a key that has a picture like a hand on it
then press that key with the FN key
also some laptops has a lock right beside the mouse pad itself which will enable or disable the mousepad
good luck
if all else fails go to device manager
scroll down to pointing devices
un install it
then restart ther laptop
and windows should re install the driver on startup
hopefully this will correct the problem
hope this will help you
Aug 14, 2011 | Computers & Internet
How do i unlock my videocon AC remote???i see a key symbol on the top right corner of the remote screen.
When not in a setting mode, pressing and holding UP & DOWN keys for 3 seconds,
the key pad is locked. After setting it, the LOCK icon will be displayed on LCD to
indicate that key pad has been locked and all the keys are disabled. At that case,
the remote won't send out any codes. The LOCK icon on the LCD flash 3 times,
0.5 seconds for ON, 0.5 seconds for OFF, and press & hold UP & DOWN keys for
3 seconds, the remote is un-locked.
Jun 26, 2011 | Heating & Cooling
When I jostle the phone it will dial a number from my contacts. Is there a way I can disable the dial pad?
pressing the Home Key then the Space Bar will temporarily lock the key pad, can be un locked be pressing the Left Soft Key
Sep 14, 2010 | Motorola Mobility Moto Q
I have a 2001 Mercedes S500 and the trunk will not open by any method, not even with the key now. As I press the lock button I hear an air sound but the lock will not un-latch. Is it possible to release...
first try with mettle key blade insert mettle key blade in to the boot lid key hole witch is near the rear number plate light at left hand, then
1 turn key fully left and press it in if not work
2 press key in and then turn fully left
did it work? if not you have to do some other way to do it before do that try several time no 1 and 2 might work if still not work do as fallow
send me a contact email my email is merctechnique@yahoo.co.nz It's not a good thing to publish thieves can use it to rob cars.
Sep 11, 2010 | 2001 Mercedes-Benz S-Class
My keypad is locked.please help me
ky keypad is locked by security code what can i do 4 unlock 2730c
Aug 12, 2010 | Nokia 2730 Cell Phone
I forgot my keypad unlock code
Please do these follow steps, I'm sure you can solve it:
1. Remove your phone battery and then insert it agian.
2. Turn on your phone and be sure you the phone not auto lock key pad.
3. Reinstall your phone firmware use Nokia Software Updater (update all data before you do that)
4. Enjoy what did you do!
Mar 14, 2010 | Nokia 5310 Cellular Phone
Forgot password
Use Soft Key Reset
REMOVE YOUR SIM CARD
Locate your soft keys on your phone, should be buttons above end and send.
Press and hold both soft keys.
Locate reset button on your phone should be on side and in center you may need to use your stylus to depress it.
Gently press the reset button while still holding the soft keys, release the reset button but continue to hold the soft keys.
In about 10 Seconds it should ask you to confirm the reset, once you do it will be set back to manufacturers settings.
Hope this helps
Sep 25, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Un work of the doors auto control lexus
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Long beep to follow if successful.
Jun 16, 2009 | 1996 Lexus LS 400
Nokia 5310 Cellular Phone Logo
229 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
