Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
The pro scrub light is always on.
Lately after the dishwasher stops the light stays on,sometimes all the time
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
Nov 20, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
Dishwasher will not turn on, clean light is flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | KitchenAid Dishwashers
The clean light blinks 7 times an stops then repeats also if you set up to wash nothing happens. What does the brinking light mean?
  1. Crack open door
  2. Within 3 seconds push Hi-Temp Scrub, Heat Dry, Hi-Temp Scrub, Heat Dry
  3. Close and latch door
  4. Press Cance
Try the above steps and also check the video in link given below to know detailed explantion on what the light means
http://www.youtube.com/watch?v=Hv7xOaucH7I
Aug 29, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwasher cycle "holds'
hi there,
check the keypad. it has a ribbon cable that plugs into the control board. it may be loose.
Sep 23, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
98 Pontiac Grand Am GT, several problems...
sounds like a faulty speed sensor or a bad tone ring which is probably inside the hub on this model
Jun 25, 2008 | 1999 Pontiac Grand Am GT
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
11 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
