Question about Dometic Rooftop RV Air Conditioner
Whin i turn air on furnace comes on
When i turn thermostat to furnace ac comes on
    Genius:
  • Dometic Master
  • 1,363 Answers
Thermostat or communication cable to relay module issue.
Posted on Aug 18, 2015
  • 230 Answers
SOURCE: will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Posted on Jun 17, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
  • 68 Answers
SOURCE: ATWOOD MOBILE FURNACE RUNS WHEN IT WANTS/
Check your furnace for power. will be 4 wires. power ground and 2 thermostat wires. Check for power at the time delay relay, if you have power there check for power going in the fan motor, if power in motor wire, motor is bad. If no power in motor wire and power going to circuit board take the 2 thermostat wire apart and wrap the 2 together comimg from the thermostat. Fan will stat in about 30 seconds. If it does you need a control kit in the ac. But sounds to me like you have a furnace problem.
Posted on Mar 19, 2009
motor1258
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
  • 10 Answers
SOURCE: I have a suburban lp furnace and duotherm air/heat
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Furnace will not run when hooked up to electricity
Go to your thermostat and access the fan mode. Change the fan mode to Automatic, AU. This will stop the AC fan from blowing when the furnace is turned on. If the fan mode is on Hi or Lo and the furnace is turned on it will turn on the AC blower. Bad design...
Mar 02, 2014 | RVs
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
My thermostat says -AC WHAT DOES THAT MEANB
Turn your fan from auto to on at thermostat, fan should come on. If
you still get the (AC) and fan does not come on, change the batteries at the thermostat if they have them..
To see if thermostat is bad, do this.
1) Turn power off to Furnace/AirHandler.
2) Remve Bowler Door and find where thermostat wires connect to control board. Remove wires and write down which terminal they go
to.
3)Take a wire and hook-up between R and Y. Put door back on, turn power on. Fan should come on and AC should come on.
Jul 11, 2010 | Goodman CLQ36AR49 Air Conditioner
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Furnace problem
The problem is most likely in the control module of the roof air unit. Dometic uses the thermostat to activate and deactivate a relay in the control board of the roof ac unit whiich is just visible when you remove your air intake screen. The two blue with white stripe wires are the furnace control wires.
The furnace turns on and off by the opening and closing of relay. Most likely, the furnace control relay is stuck in the on position. On the thermostate, remove the fur wire and see if the furnace quits afrer it cycles down...it does not quit right away. With the termostat out of the loop, if the furnace does not shut down, the problem is in the control box. They are not hard to replace but you must be careful with the live wiire from the 110 ciucuit breaker. If you are not comfortable with the repair, take it to a dealer. The part number is on the assembly box. They need to know if you have the heat srip option or whatever othert options our Roof AC has. If the furnace still runs with the blue/white wires disconnected, the furnace wires are shorted somewhere between the furnace and the AC control unit.
Aug 21, 2007 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
