Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
No power I have a 3 HP craftsman air compressor . The motor is not sufficiently strong enough to turn compressor. I have checked the wiring with a megameter and checked to ground. Everything seems normal. I have replaced the start capacitor and checked the run capacitor which tests out ok. When I run the motor I can hold the pully and keep it from turning, I checked the wireing diaghram and it appears that the correct wires are at the correct terminals. Can anyone give me some possible solution (besides tossing the motor).
  • boss dad May 11, 2010
    did you just get this compressor --- make sure the motor is setup for either 110 or 220 depending what your plugged into. sounds like a 220 motor setup to a 110 supply.Otherwise, you will have to toss the motor ( i hope the pulley isnt loose at the motor shaft )
  • 76 Answers
I think you have a bad phase or you are not getting the correct volts going in try switching the hot wires red to black and black to red and check each set of windings for continuity
Posted on Jun 23, 2009
  • alex MACHELL Jun 26, 2009
    how is my advise working out are we solving the problem yet get back to me and let me know i can get the schematic if we need to what brand of motor and i will need the model # and serial # plus the specs from the plate or sticker on the side of motor
Air compressor issue
Sounds to me like a power issue, is your machine a single or 3 phase? Do you have an extension lead fitted to it? As the pressure builds, the motor needs more juice to turn it, if the power source isnt powerful enough then the motor will slow down, you might need to check that before looking at the compressor itself.
Aug 31, 2012 | Campbell Hausfeld Air Tools & Compressors
I have a Craftsman 33 gallon vertical air compressor with reduced noise motor. After not using it for a couple days, it won't start. There is power to the motor. Turned the pulley with power on in both...
The HP is to low for the 33 gallan copasity of the tank 6 hp is not enough If you are trying to run things that draw a large CFM . The disgin of the mechine is incorrect sorry its one mans oppoin the thing can't do what it says it can
Apr 07, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Problem with the craftsman 30 gal compressor 6 hp vertical oil free. motor or compressor will not engage, when turned motor starts for a second and sound slow then pops the breaker
sounds like you are not getting enough voltage to run the compressor if you are using an extension cord check your manual to see what gauge it should be depending on how long it is if you are plugged into a wall outlet then is the compressor the only thing that is running on the circuit if some thing else is running then you may be overloading the circuit.
Feb 24, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have craftsmen 7gal 1 hp-looks like very low oil level and no motor starts-just momentarily noise and stops?
1.If it has a low oil level, have it refilled to proper level,
and restart.
2.If it does not start. Isolate the motor from the
compressor, by removing the v-belt.
3. In this manner, we will know where's the trouble.
4. Put power to the motor, and have it started.
5. If the motor start, then it is okey. If the motor
just groan and does not start, check the starting
capacitor, it may need replacement.
6. Check the compressor if it can be turned (one to
two full turns). If it can turned, then, it is okey.
Otherwise, check the compressor piston rings.
It may need to be replaced.
7. Reassemble your compressor and replace the
v-belts.
8. Then, you can plug in to the nearest power outlet
and start the compressor.
Nov 01, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have sears craftsman 22gal 5 hp air compressor not enough press
hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Oct 05, 2009 | Air Tools & Compressors
Leaks air at the pressure switch
start your compressor and let it buid up pressure to turn off. then unplug from power.lossen the fill tube that goes from the pump to the tank. when you loosen it. if it leaks air then your check valve is bad and will have to be replaced.
Dec 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 6hp / 60gal air compressor
Does this trip on pressure or is it a breaker tripping? If you took off the intake then there is no pressure build up, thus it wouldn't trip the pressure switch. But would at the same time add a load to the motor. First check and make sure motor is wired properly, then check that pressure switch is wired properly and is adjusted to the right pressure. I don't believe that the intake tube would be clogged, it's a straight hole into the tank. But could be a possibility.
Oct 23, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
171 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
