Question about Mirage Audio Players & Recorders
Mirage subwoofer bps 100
There is a red light on the back of this unit. Is the light a power indication or overheat indication
3 Suggested Answers
  • 14 Answers
SOURCE: Wharfdale PC 10 subwoofer
Some basic trouble shooting is required here. First you need to see if it is a problem from your source or the sub. Try a different source to the sub-woofer and see if it changes the response. If still nothing on the sub, then most likely there is an issue with the amp or driver. Check to see if there is a fuse on the sub, if so, it could be blown. There could also be an issue with the auto switching circuit on the subs amp, in that case, it would need to be repaired in the shop. But before that I would check all of the connections to the sub, and also to the driver in the cabinet. If everything looks good, then put some type of source directly to the woofer to see if it works, if you get sound, then looks like the amp has a problem. Again a repair or replace issue.
john
Posted on Aug 20, 2008
  • 334 Answers
SOURCE: what is the impedance of
The high Level inputs are suitable for an 8 ohm amplifer The low level inputs would be used to connect via your amplifer's pre amp output.
Posted on Jan 07, 2011
I have a corporate express shredder (CEBM6). Half way through a shredding job the overheat light came on and now the shredder wont go forward or back. I've shut it off to let it "cool" - how...
The unit requires a complete cleaning and oiling , there is paper shreds jammed at the sides.
POWER OFF AND REMOVE POWER PLUG FROM WALL BEFORE CLEANING.
Staples or Grand and Toy should have the shredder oil.
Jun 14, 2011 | Corporate Express CEBM6 Shredder
Screen is black: eventhough the red power buttons on will not respond to power on button.
tv will not turn on. Red lights indicate power to unit, no change when on button is pushed. I have tried powering the unit down with the master power button and also unplugging the power cord from back of unit. No change
Aug 11, 2010 | Hitachi 26HDL52 26 in. LCD Television
3 red lights on the front of my x box 360
This can be caused by dust buildup in the unit, causing the unit to overheat. Once the unit overheats it causes solder on the board to bridge (connect). Check with microsoft to see if this unit is still under warranty with this site: http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
If the unit is not under warranty go to: www.wiredextreme.com. We are a console repair company based out of Dallas, Tx. We can get your console up and running. All of our repairs come with a 90 day warranty for the whole console, not just what we repair. We also offer extended warranties for up to 4 years at an additional cost.
Jan 05, 2010 | Microsoft Xbox 360 Console
Three flashing red lights
3 red lights happens because the GPU and the CPU overheat and shut down to prevent damage, you will need to send it in to get it fixed, or you can fix it yourself using a good video guide
Dec 18, 2009 | Microsoft Xbox 360 Console
There is no air coming out of the back of the console and two red lights are flashing after it overheats we think the fan is broken because as soon as you put it on it switches off completely
2 flashing red lights means the unit powered off because of an overheat.
If there is no air moving out the back of the unit the fan is definitely shot. If you're still under warranty, send it back to Microsoft and let them fix it.
If not, buy a replacement fan for $5 and fix it yourself.
Oct 11, 2009 | Microsoft Xbox 360 Console
1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Jun 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Disc won't eject
press the disc eject button
Jun 25, 2008 | Sony PlayStation 2 Slimline Console
TH-42PZ700U
Try unpluging the power from the unit for a hour then reconnect it, if it turns on for a couple of hours then turns off, you have a overheat issue. If it stay on, then it just needed reset, if it dosent turn back on, then you need to have it seviced, for a power failure in the system.
hope this helps if not reply back before marking not helpful. thanks
May 11, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
57 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
Rob
Rob
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
