Question about Hunter Ceiling Fan Remote Transmitter 85095-01
Hunter fan remote 86682-01 - Hunter Ceiling Fan Remote Transmitter 85095-01
2 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: I need a hunter remote control unit part
This particular Hunter remote control unit has been known to have interference issues for some time now. It is very suceptible to picking up other transmissions, such as those from TV remotes, etc.
If you're having intermittent operation of the fan and/or light, you can try setting different codes for both the receiver and the remote.
That being said, the best source for a replacement unit is directly from Hunter, since you might also still be under warranty you might get it replaced for free, if you remembered to fill out and mail the warranty card!
Of course, if you just want to replace a lost or broken remote, give them a call and order one (or two and have a spare!).
To speak with a live Technical Support Representative call: 1-888-830-1326 (United States) 1-866-268-1936 (Canada) Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
THE LIGHTS ON MY HUNTER CEILING FAN WILL NOT LIGHT UP BUT THE FAN PORTION WORKS WELL
If your Hunter fan uses a remote control, the light portion of the remote receiver probably has failed. It is a common problem with remote-controlled ceiling fans in general.
Jan 29, 2017 | Hunter Dryers
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Remote will not turn on fan. A ll I get is a click.Light works fine
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... http://www.fixya.com/support/t11813083-cp9430r Cp9430r Fixya
May 30, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan remote 27144
reset the code and test again.
God bless you
Feb 18, 2013 | Hunter 27144 Universal Remote Controls...
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Red light does not come on when buttoms pressed ,even with new battery,an I obtain a new remote?
Hi and welcome to FixYa, I am Kelly
Kmart and Sears both have replacement remotes for Hunter Fans.
Look on the back of your remote for the model number and you can search
http://searspartsdirect.com using a model search for a replacement.
You can also call the Hunter Fan Company to find out the model of your remote here:
1-888-830-1326. They will ask for the model number of your fan.
The Hunter remotes for the original fans can be one of these 3 models: 27187, 22691 or 27189.
See if you can find one of those 3 numbers on your remote.
Thanks for choosing FixYa,
Kelly
Apr 25, 2011 | Hunter Designer's Choice 5-Switchblades Lg...
Hi, I just moved into an apartment that has a
The grand isle will work with only that remote, you will need to contact Hunter at 1-901-745-9222 to get the remote you need.
If you let your landlord know your problem they may re-imburse you for the money incurred purchasing the remote. It's worth it to get the remote though, this is a high quality fan.
Sep 19, 2010 | Hunter 25746 Grand Isle White Ceiling Fan
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Dec 28, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
359 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
