Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Where do the black and the white wires go to that became disconnected when I was disassembling it to get to the motor (main).
I remember seeing this exact question awhile ago but there wasn't an answer and I haven't been able to locate the website I found it on again. When I was taking apart the main motor housing, I had a friend watch carefully as I separated the pieces and I'll be darned if the 2 wires didn't pull off their connections and neither of us saw where they came from! I haven't been able to find a wiring schematic. Thank You.
    Top Expert:
  • Dyson Master
  • 40,378 Answers
Request a wiring diagram (not a schematic) directly from Dyson.
Posted on Jul 21, 2017
SOURCE: How do you take the DC11 apart?
Unplug the unit from any power first.
To get the unit apart you have to Carefully pry off the wheels from both sides of the unit to allow access to another 4 torx screws. Use a longer flat blade screw driver and insert this between the wheel and the body of the vacum as close to the wheels center of rotation as much as possible. This should allow you open the clamshell like case. Once inside you can test the power switch and connections. My switch tested good but there is a problem with the power cord that I am trying to determine.
I am trying to replace the cord but the cord reel assembly and cord seems tighly integrated so I may end up buying the replacement power cord assembly if it is available for purchase to the general public and not only service centers. I will try the plug into the wall assembly first as it is easier to replace.
Good luck
Posted on Oct 25, 2008
  • 389 Answers
SOURCE: Connecting motor part
Hi Charlotte,  Yes, colour coding of wires is a nightmare, isn't it!? Red and brown both signify "live", and blue and black both signify "neutral".  So you should connect brown to red, and black to blue. I hope this is helpful. If you need more guidance, please post here again and I'll see what more I can do for you. I value your feedback, so please remember to rate my response. Good luck!
Posted on Mar 04, 2009
  • 379 Answers
SOURCE: have got motor out of dyson o7 and cannot see
The two brown wires connect to the switch, and the two blue wires connect together. has some good info.
Posted on Oct 15, 2009
  • 456 Answers
SOURCE: The wires feeding the brush bar assembly to my
if the spade connectors are the same size then i would connect white to yellow and then blue to black
Posted on Apr 03, 2011
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: The brushbar on my model
    I'm sorry to hear you're having difficulties with your DC17. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to, someone will be in contact as soon as possible. We'll look forward to hearing from you.
    Kind regards,
    Dyson Online Customer Support
    Posted on Sep 06, 2011
    How to replace brush bar motor
    It's not easy. The cleaner head assembly is hard to get off the main frame. When you get it there are 4 hex screws to the motor cover (hard to turn). Then a black and a white wire go into the unit. The wire cover can be removed with one hex screw but you still can't disconnect them. You have to remove the housing on the main drum (which I haven't done yet). I was looking for a picture like this all day. This is a shot I took today, apparently the only shot of the motor in the housing on the entire web. bc2d0b10-525a-469b-953c-57c5fd2f36e0.jpg
    Jul 06, 2015 | Dyson DC17 Animal Bagless Upright Cyclonic...
    You should only have 4 wires to hook up to an Oreck motor. The black wire from the cord coming into the back of the motor housing will be attached to the closest lead when the motor is in it's normal position. Most of the time there will be a black dot next to the terminal. On the other side of the motor you should have two white wires that should be connected together, one from the same cord just mentioned and the other one coming from your lights. Those two wires should also be connected to the motor where there is a black dot beside the terminal. Your last black wire coming from the lights should go to the terminal next to where the white wires are connected or to another terminal that is on that side of the motor. Hope this helps!
    Mar 14, 2015 | Oreck Single Speed Handle Assembly - White...
    How do I wire an oreck xl9100 motor
    The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
    Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
    How do i reattach wires to motor from cord and lights
    Black wire from the power cord goes onto the wire connection closest to where it comes into the back of the vacuum. There should be a black dot beside the wire connection on the motor. On the other side of the motor, there should be another black dot beside a wire connection and the two white wires will go there. The white wire coming from the lights usually has a double connection and it will go on first and then the white wire from the power cord will go onto the other side of the double connector. The black wire coming from the light usually will go to a wire connector right next to the white wires or just above it . Hope this helps!
    Jun 02, 2014 | Oreck XL Deluxe U3700 Bagged Upright...
    Can't hook up power cord to main motor on Hoover model F5915100
    You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
    Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
    Ametek wiring diagram for a Oreck XL21 600 ECB
    I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
    Sep 22, 2013 | Oreck Vacuums
    Replaced Oreck power switch. 2 black leads and 1 white lead for switch. Posts marked 1, 2, and 3. 2 black wires to switch powers on. Connect white wire and breaker trips. Where does the white wire go?
    Both black go to the switch. Power in - black to switch / white to white from motor.
    From motor - black to switch / white to white from power cord
    The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
    Nov 01, 2010 | Vacuums
    Sprayer not functioning
    You can disassemble the unit and check to see if the pump motor has seized.
    the motor has a black, red and green wire attached, is encased in a plastic housing, and is right next to the vacuum assembly. Don't cut the line attached to the plastic housing, you don't need to and it can be a pain to reattach later. just slide the whole white housing up towards the black vacuum assembly, and undo the wire leads attached to the motor, they just pull off (make sure it's not plugged in) making sure to note which wire attaches to which lead... i marked each lead with a colored marker to be sure.
    Use a pair of pliers to turn the drive shaft if it has seized, and be sure not to lose the small rubber o-ring that sits around the shaft. Lubricate at the base where the drive shaft meets the motor with just a drop of 3-in-1 electric motor oil and then reassemble the housing, attach the leads, seat the motor back into the seating (make sure the bottom nozzle goes into the green water feed coupler!) and reassemble the case.
    worked like a cham for me and i saved $10
    Jul 20, 2010 | Bissell 1400 Little Green Pro Canister...
    I had a loose wire in my Oreck XL motor. I took it
    Lights are 12 volts.
    The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
    Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
    One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
    Aug 07, 2009 | Oreck XL Ultra Bagged Upright Vacuum
    I have the same vacuum at home and can take a picture, but I believe it is wired in this order. Hot wire (black) from cord goes to the switch then the switch to the fuse, then the fuse to the cable that goes down to the light and motor. The neutral (white) wire from the cord is connected to the neutral (black with white stripe) side of the wire going to the motor and light.
    Jan 26, 2009 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
    Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
    37 people viewed this question
    Top Dyson Vacuums Experts
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
