Question about Ultratab JAZZ-C925 Tablet PC - MediaTek Cortex 1.2 GHz Processor - Wi-
How do i repair c954 usb charger port - Ultratab JAZZ-C925 Tablet PC - MediaTek Cortex 1.2 GHz Processor - Wi-
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit.
Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing.
Try using a different charger that will deliver 5 Volts at 2 Amps...no less.
If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
Mar 12, 2014 | Insignia - Flex 10.1" Tablet with 16GB...
Repair 2012 nexus 7 charger port
The micro usb charging port on the nexus 7 is notorious for becoming useless b/c cords fit loosely in the port right out of the box. Micro usb cords get wiggled and jiggled because of the size of the opening and then the port will no longer charge b/c solder breaks from the board, or the tongue inside the port partially breaks apart.
You can buy the replacement micro usb / headphone jack assembly for about $50 and do the repair yourself (hopefully) ...or you can send it to us and we\'ll replace just the jack and ship it back to you all for $54.95
More info and our repair form is on this page:
http://www.rockhoptec.com/services.php#t...
Mar 04, 2014 | Tablets & eReaders
Power port needs repaired
Are you sure it is the port that needs fixed, or is it your usb cord you plug into? If it is the port you need to send the tablet in for a technition to repair. First try a new charger or usb cord and see if it works.
Feb 23, 2014 | Android Ainol Novo 7 Paladin Tablet PC
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
Jan 07, 2014 | Samsung Galaxy Tab 2
Charger port repair
You can just replace the charger port module. It is pretty much plug and play, but you have to open the back covery. search model name plus "repair guide" on any search engine.They will show details about about part replacement etc. in detail. The part is available here http://www.portatronics.com/product_info.php?info=p12158_Google-Nexus-7-USB-and-Headphone-Jack-Module-USED.html
Jan 06, 2014 | ASUS Nexus 7 FHD Second Generation Tablet...
The charger is broken and i need another charger also the pieces of the charger is stuck where you are suppose to put the charger
You can charge your tablet through the USB port on your desktop computer. Just plug it in with the USB cable that came with your unit. It's slower charging but who cares?
Those pins are delicate. Be careful when inserting and removing.
The USB is designed to power on first and then the data is transferred.
Forget about taking it to a repair shop. The charges will be more than the tablet is worth and it's not likely they will have the part.
Dec 30, 2013 | Proscan 10.1-Inch Internet Tablet,...
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
Ultratab JAZZ-C925 Tablet PC - MediaTek Cortex 1.2 GHz Processor - Wi- Logo
62 people viewed this question
Top Ultratab Tablets & eReaders Experts
Are you an Ultratab Tablet and eReader Expert? Answer questions, earn points and help others
