Question about Refrigerators
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Posted on Apr 27, 2017
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
SOURCE: Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the
ice buildup is allowing conductive cooling into the refrigerator
section and therefore is allowing condensation on the refrigerator wall
or ceiling.
4 The refg section has a heater (possibly not positive) in the area of
the door frame, or it may have a "power saver" switch. This switch and
the heater (if it has a heater it may not have a switch) are designed
to stop condensation on the refridg while running. I fit is placed in
the "power save" mode it turns off the heater. But, if you live in
extream humidity (Great lakes east side or Gulf coats Houstion...) the
humid air will condensate water out and it will collect and settle on
the floor.
5 Door gaskets are not sealing especially on the bottom of the door.
This allows warmer air into the fridge section and it is condensation
on floor under the crisper.
If you check all of these items and still cant find it please post back
and tell me what you did find. So I can help you more. Please rate me
as much as possible as Im trying to keep my average up and do the
things that will actually educate and help people.
THANK you for using fixya and good luck..
Posted on Mar 22, 2009
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
SOURCE: Water leak from my Kenmore refrigerator
Your problem is most likely a clogged drain line. Which is located in the back bottom of the freezer a little hole. Run some hot water down it with a spray bottom and it should resolve your issue. Also yes a Tech will be able to fix this problem
Posted on Jun 01, 2009
SOURCE: My Maytag side by side (no icemaker) keeps leaking
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me. If this helped vote or rate me. Thanks Sea Breeze
Posted on Jun 22, 2009
Apr 27, 2017 | Refrigerators
Mar 12, 2014 | Maytag MFD2560HES Bottom Freezer French...
Aug 28, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Oct 22, 2010 | Maytag MFD2560HES Bottom Freezer French...
Sep 09, 2010 | Maytag Admiral Top-Freezer Refrigerator
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Dec 22, 2009 | Maytag MBF1956HEQ / MBF1956HEW /...
Aug 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Oct 28, 2007 | Refrigerators
Apr 25, 2018 | GE Refrigerators
26 people viewed this question
