Question about Canon GL2 Mini DV Digital Camcorder
Does the sd card for a cammon gl2 have to be formatted
    Master:
  • Canon Master
  • 442 Answers
Yes, it does and should be done in the camera and each time you download the images just to keep it in best operating condition. Switch to VCR/Playback mode and reformat the card from the menu option (see your manual). Also note that if you're having issues with the camera reading a card be sure it is one that can be used and does not exceed the GL2's maximum card size (though I don't recall what that is).
Posted on Jun 02, 2014
2 Suggested Answers
  • 29 Answers
SOURCE: When I try to format an SD memory card in my
how many gb is your card? whats the size of the card shown on the computer? any past experience with redundancy error when extracting data from the card?
Posted on May 07, 2011
Formatting sd card
The GL2 uses SD cards, which max out at 2GB. It will not use higher-capacity SDHC cards.
Aug 22, 2013 | Canon GL2 Mini DV Digital Camcorder
Okay!!! So I put in this SD 16gh something card & it shows on the screen of the camera "tv screen" and it has a blue background with green arrows that seem to be uploading something but really it
The GL2 works with SD cards. Your 16GB card is an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to use an SD card, 2GB or smaller.
Jan 05, 2013 | Canon GL2 Mini DV Digital Camcorder
When I try to format an SD memory card in my cannon gl2 it never finishes the formatting. The only way to stop it is to remove the power source. What's wrong
May 07, 2011 | Canon Video Cameras
How to format or unformat memory card on IXUSi camera I need to know how to format and unformat the memory card I can't see the pcitures as it is showing no image on the screeen Regards C Robertson
to format a sd memory card, you can insert the card to computer or camera, and select the format. To unformat a sd memory card, a data recovery software can help you.
Are you in a dilemma as to whether to format your SD card or not? If you don't format the SD memory card, you cannot use your SD card any more, and you cannot transfer files from SD card to other devices. If you format the SD memory card, you will loss all the files like photos and videos on your SD card. Follow the link you can get the answer.
Jun 28, 2010 | Canon IXUS 80 IS Digital Camera
How to format the microSD?
actually u shold format it by the device in which u are going to use. eg camera. This will enable correct formating for usage of this device.
otherwise their is a standard Sd format and u can use that to format
You can format the card by SD card Utility. SD utility is a format utility which is release from SD Association. It is a standard for all SD type card and will self determine the SD card's file system. Please kindly refer to the link below for SD format utility download webpage.
http://www.sdcard.org/about/downloads/
May 05, 2008 | Kingston 2GB Secure Digital Memory Card
Formatting SD card
I had this problem too. Some SD cards won't properly format. My trick was I formatted the card in a different device first (canon Powershot A-630) then put the card in the R-09 and formatted it again. it took about 8 seconds for a 2 gig SD card to format.
Mar 05, 2008 | Edirol R-09 Digital Voice Recorder
Card Error
From what I know, and card over 2gb needs a different reader. in this case, I am guessing that the card is an SD card. If you look carefully, you will see HC right below the SD logo. these are High Capacity SD cards, totally, different from traditional SD cards. so what you need to do, is find a 4gb regular SD card (highly doubt one exists) or get a smaller regular SD card (2gb Max I think)
Feb 05, 2008 | Canon GL2 Mini DV Digital Camcorder
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon GL2 Mini DV Digital Camcorder Logo
89 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
