Question about Citizen Womens Watch|World Time A-T|FC0006-52D- Citizen
Hot to set Day of week on FC0006-52D? - Citizen Womens Watch|World Time A-T|FC0006-52D- Citizen
Wrong day of the week setting on my Casio 5121
Try Googling (casio)(5121)(manual) without parens for instructions.
Jun 10, 2017 | Casio Watches
How can I change the days in casio Ef 331
First of all avoid setting the day and day of the week between 9.00 pm and 6.00 am. The day and day of the week may not change in the following day if you do.
Try this,
1) Pull the crown to the first click.
2) Set the day by rotating the crown counterclockwise.
3) Set the day of the week by rotating the crown clockwise.
4) Push the crown back to its normal position.
Hope this will help.
Cheers
May 16, 2016 | Casio Watches
How to set day of the week
press mode 3 times , then press reset 5 times and press start to change the day
Aug 10, 2012 | Anne Klein AK SilverTone Diamond Accented...
How to set the day on the timex, as i am able to set the date but i dont know how to set the day of the week in T46601-V1 model watch
it can only set by turning the time for 24 hour using the crown the day of the week changes every 3 AM, i hope i had helped you.
Sep 10, 2011 | Timex Expedition T46601 Watch
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
How to set day of week mini dial?
Pull out the crown and advance hands forwards. When the hour and minute hand will pass 12 o'clock (midnight), you will notice the day hand will jump to the next (following) day. Advance hands as long as needed to reach the desired day.
Rate me, please.
Jul 23, 2009 | Invicta Square Angel Diamond Chronograph...
Change the day of the week
Most watches have a stem that you pull out to set the time. The little knob on the end of the stem is called a crown. For a day/date watch, there are two clicks. The first click when you pull out the stem is the day / date setting, the second click sets the time.
When you are on the first click, twisting the crown one direction changes the day of the week; twisting the other direction changes the date. If yours has only the date, it could be either direction depending on the manufacturer.
Jun 15, 2009 | Guess Collection Textured Dial Watch
Setting Date & Day
Two clicks to the dial on the right. First click adjusts the day of the month. To change the day of the week pull out to second click and go forward or backward in 'time' and week will follow.
Apr 11, 2009 | Watches
Can't set day of the week for armitron MD06117 mens watch
Purchased my Armitron men's digtal watch in 2009. Here's the twist on setting the name of the Day of the Week on my watch. When you get to the name of the Day of the Week flashing.. you don't get Su...Mo...Tu... You get 01..02..03... up through 99. (You think.. what the hell is this??) DON'T TRY TO SET Sun.. Mon.. etc here.. you won't find it. The puzzle solver..and it is.. IS TO SET THE LAST TWO DIGITS OF THE YEAR HERE.. Example... it is now 2010.. so scroll thru the numbers and set it to "10"!! Now.. when you go and set the numerical day date e.g. 3 for March, and set the numerical day - e.g. 15, the on-board computer?? in the watch will AUTOMATICALLY SET THE NAME OF THE WEEK!! It will look-up For Example.. in the year 2010.. 3-14 is SUN.. and will set it as that!! Hope this saves you some frustration. Regards... klsdad@mindspring.com (Mar 14, 2010)
Mar 06, 2009 | JCPenney Armitron Sport Link Bracelet...
Setting day and date on timex watch
Pull the stem out part of the way not all of the way. This will allow you to change the date quickly without the day moving.
Nov 26, 2008 | Timex 27191 Wristwatch
Citizen Womens Watch|World Time A-T|FC0006-52D- Citizen Logo
13 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
