Question about Roper Washing Machines
Manual RTW440XQ0 Is there a filter on the intake connection for the cold water?
2 Suggested Answers
  • 50 Answers
SOURCE: cold water filter is clogged - how to clean?
the water solenoid valve is cheap enough you could just buy new and put in. wouldnt waste my time trying to clean it just replace it.
Posted on Aug 01, 2010
Soloniod faulty
check the filters
at the intake the solinoids {water intake valves}
there is a small filter
you need to turn of the hot and cold water
like under the sink
take off both hozes hot and cold
then take out the filters at the machine intakes
and clean them
you can take out the filters
using flat nose plyers to gently pull them out
clean them out from brown crypto spyridion carcus
and other rubbish
you can leave the filters out and run thru the whole machine on like 30deg with a calgon tab
does help {not scotland no lime here }
then place the filters in the intakes again
or replace the valve if it leaks water after cleaning
then the spring in the valve of the valves solinoid coils isnt so good
and needs replaced
but can just be a blockage
above all if its a new machine you just got
perhaps it been in a low presure area so the valves will be
low presure hot and cold
usually its just the hot that is low presure
so you need to check the cold water is getting plenty on like 2 -3 bar presure...
Mar 05, 2015 | Washing Machines
Lost of power
Are you running a cold air intake?? Maybe water is getting into the intake and engine.. make sure theres no way for water to get into the air intake...you know where the filter goes? Check owners manual
Apr 14, 2014 | 1997 Suzuki Baleno
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
Which is cold water connection on the boiler
Incoming cold water usually connects to nipple marked with C, and/or the nipple that feeds into water filter (if unit has built in filter)
If unit has shut-off valve, then shut off is located on cold line.
If unit is operable, then turn on hot water and see which pipe gets hot ... and then cold is other pipe.
read your product manual.
Search your brand and model on internet to locate product manual.
Otherwise re-post question and include brand and model number so product manual can be located and information can seen first-hand.
Gene
Jul 18, 2013 | Water Heaters
I think i have an crack block because water is coming out of my air filter
It sounds like the gasket between your throttle body and intake is damaged, Your throttle body is water heated to assist in cold weather starting and if this gasket fails it can allow water into the intake and depending on the angle of the intake can cause water to run into either the motor or into the air filter.
Mar 04, 2012 | 1997 Buick Park Avenue
Cold water filter is clogged - how to clean?
Aug 01, 2010 | Estate TAWX700JQ Top Load Washer
I have the LG WM1832cw washer. Something is wrong with the cold water fill. Not the hot water just the cold water fill valve section as it fills VERY VERY SLOW (water trickels in). Hot water fills fast! I...
Is resistance between each terminal of INLET
VALVE ASSEMBLY 0.8~1.2 kω? If not replace it.
Is the inlet valve filter clogged?
Clean the filter.
Verify the voltage of the inlet valve connector is
120 V AC. No voltage? Check electrical connection.
Replace the MAIN PWB ASSEMBLY.
I have an LG training manual which might not be the exact one you need but it gives an idea what to look for.
LG WASHER REPAIR MANUAL
Post your model number at any of these
fine forums for an answer
that will save you big money::
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
NEW! http://sublimeforum.invisionplus.net/
Nov 10, 2009 | Washing Machines
F 13 problem indicated on miele g2420 optima dishwasher
Its on the end of the water intake line - ussually under the sink - connected to the hot water line.
Dec 06, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Mieli water-intake light comming on?
I think it's regular salt, yes, but I've never bothered to fill mine.
Have you had a dishwasher previously? If not, check the tap where your washer gets its water to make sure it has proper water preasure. If the washer doesn't get enough water it will stop.
In my kitchen there is a separate little knob on the tap to control the water to the dishwasher. this has to be open. Mine has hot and cold selection, but only cold is connected so if I turn it on hot the washer gets no water
Nov 07, 2007 | Dishwashers
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
