Question about NAD C370 2-Channel Amplifier
No base in one speaker - NAD C370 2-Channel Amplifier
    Novelist:
  • 217 Answers
Usually this is because the base driver in your speaker is shot. I have repaired hundreds of amplifiers and have never found just the BASS being low at the output of the amp. If the amp is working, then the likelyhood of the speaker being defective is good. A quick test is to just swap speakers and see if the problem moves to the other channel.
If you have a very old transistorized amplifier, you may have a large value coupling capacitor between the actual amplifier circuitry and the speaker output. This is because the older amps had a large DC voltage at the output of the amplifier and this had to be removed or the speaker would be damaged. This capacitor may have finally given up the ghost and needs replacing. While you are at it, you may as well replace both as the other is soon to go.
My bet is that the woofer in the speaker cabinet has blown.
Posted on Dec 07, 2014
Bad sound quality on base speakerphone/answering machine
Hi , mostly in this case , the speaker in the base unit is defective . change the speaker.
Jul 09, 2012 | Panasonic KX TC1743B Cordless Phone
Dont have accoustimass can i substitute
Bose is specific about how speakers are designed and how the seperate units are connected. It is easy to damage a Bose speaker that is suposed to be connect to a base reflex unit. The base speakers filter out the low frequency that will destroy the small speakers, and speakers that are too large will damage the base unit.
These units can be mixed together only in certain ways, none of which Bose will aporove or honor warranty if you violate the terms of use. Bose systems in the home theater market receivers are specific, and cam damage the amplifiers if you try to mix other speakers with the system.
Aug 30, 2010 | Audio Players & Recorders
Using the speaker on the base to make/answer calls
Unless your model specifically says it's a speakerphone, you can't do that. The base mic and speaker are only there for recording your outgoing message and listening to your messages. If it is a speakerphone, there should be a button on the base to activate it.
You can find manuals and other information about your model at Vtech's site.
Mar 11, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Altec lansing vs2121 model speakers blown
I have the speakers ( in perfect condition) but can not find the base unit. Do you want to sell your base unit ? Or do you want to buy the speakers ?
stevem727@gmail.com
Mar 11, 2010 | Altec Lansing VS2121 Computer Speakers
One of the speaker ports does not work, only left and center works but not right, does the base have a fuse box?
Please check if the cable connecting the speaker port to the speaker is OK. To check this, connect this cable to any other port and see if the speaker is working. If so then the internal connection has to be set right by a technician from the BOSE company as they have the necessary tools to open the Base. Yes, the base has a safety fuse to save the system from spikes.
Dec 20, 2009 | Bose (321GS) System
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Speakers losing base
if ur speakers are losing base..then check out any two or more wire may b naked.
and they wre touching each other.
so apply tape on them.
this may reduce the noise..& bass will come back.
Mar 14, 2009 | Packard Bell Speaker Computer Speakers
When i place my sirius radio into the base, driver side speaker goes off and on but most time i only hear the passanger side speaker working, I had my sirius sportster for 3 years. I think it is the base,...
when you listen to a cd or the normal radio does the drivers side speaker work? if it does then it is most likely the base is the problem. you might have a loose connection in your car. or the speaker is blow.
Jan 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Just bought a new car. i removed old stereo and put in my kenwood kdc-w808. whenever there is base in a song it distorts i have to turn my base rite down to get rid of it. worked perfectly well in my old...
your speakers probably cant handle the bass.,also they are probably full range speakers ,so hwen the base hits at the same time a voice is singing the woofer is vibrating to produce the basss,there fore distorting the highs and mids {or voice}.You need to add a seperate sub woofer.And puyt capicitossr on the full ranfge speakers to limit the bass..Rating please. :}
Jun 16, 2008 | Kenwood Car Audio & Video
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
NAD C370 2-Channel Amplifier Logo
52 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
