Question about Pentair Mastertemp 460733 250k Btu Propane Pool Heater
Breaker is popping
It was running fine. Now when it trys to turn on. The breaker pops
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Most likley ignitor is shorting this can happen if heat exchanger is leaking
Posted on Dec 10, 2014
Beckett waterfall / fountain pump W1800 pops breaker everytime you plug it in, consequently it won't run.
Sounds like there are too many things running on the same breaker. Try unplugging some of the other things on that breaker.
Oct 09, 2012 | RTO Beckett W1800 Waterfall Pump
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
Sometimes, only sometimes, mhen we run the
your microwave is ok, your breaker is bad or is not strong enough for the microwave. microwaves need a dedicated 20amp breaker
Feb 04, 2010 | Emerson MW8107WA Microwave Oven
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Circuit breaker on my air compresor pops
does the breaker pop with an empty tank?
if so then you need to see if the unit turns free,try running the m/c disconnected from the pump unit,my guess is that your drive motor bearings or internal windings are at fault
hope this helps regards ian
May 03, 2009 | Air Tools & Compressors
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Jan 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Loud Pop, blown Breaker
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Mar 28, 2008 | GE 30 in. JP340 Electric Cooktop
Pentair Mastertemp 460733 250k Btu Propane Pool Heater Logo
64 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
