Question about Cooper/regent Electrical Supplies
Twin work lamp
I have a twin lamp. One lamp works and the other doesn't. Tried replacing the bulb. What could be the problem? Where can I get a manual?
projdoc
  • 2237 Answers
SOURCE: lamp is not working and I replaced the bulb twic
if you don't hear a high-pitched whir, the colorwheel is bad. if you do hear the whir, the ballast needs replacing.
Posted on Aug 10, 2009
  • 1252 Answers
SOURCE: We have a 2003 optimal the passenger side head
You may check Headlamp relay(s): Location-Engine Compartment
Posted on Sep 17, 2011
machinetech7
  • 1344 Answers
SOURCE: After replacing the heating element in lte5243dq the thin twin dryer it still doesn't work
http://www.partselect.com/ModelFrames.aspx?ModelID=706288&ModelNum=LTE5243DQ0&mfgModelNum=&ManufactureID=3&Selected=AJ4UQMWK&Position=4&mfg=Whirlpool&Type=&Mark=3
Did you check the thermostat and the high limit thermostat. If not check them for continuity with a volt meter to confirm if they are good or not. Continuity good, no continuity bad. I posted the diagram above so you can locate the pieces in the machine.
Posted on Jun 21, 2012
  • 17 Answers
SOURCE: maytag Serial Number 2256KEQ3 - Freezer light will not work - Bulb has been replaced
change switch contact bad
Posted on Jul 15, 2012
emissionwiz
  • 76846 Answers
SOURCE: I have a PAF DOVE halogen lamp. Only the lower wattage of the lamp works. How can I tell if it's the switch or the halogen bulb? If it's the switch, where/how can it be repaired? Thanks for y
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to Factory Installed Systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Posted on Oct 31, 2012
How to remove headlights to replace bulb on twin hella.
Most German type Hella lamps are removed from inside the hood/bonnet with a quarter turn twist, and then pull straight out, remove the wiring connector first and see which way it gives when turning gently. Replace your lamp with the proper replacement from OSRAM. They make more improved versions than the OEM includes with your car. Hella uses OSRAM/Sylvania (USA) bulbs as std.
Mar 21, 2015 | Cars & Trucks
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
What should we do when lamp runtime scroll doesn't work?
1.Your lamp might be broken and you may need a new one. 2.Or you may just need to replace the scroll.
Dec 11, 2012 | Panasonic PT-L500U Bulb/Lamp
Said replace lamp, now doesn't turn on
if it was working before lamp replaced "replace lamp" appeared on the screen either lamp somehow not in correctly, new lamp bad, or something happened during lamp installation--have you tried to put the old lamp back?
Apr 08, 2012 | Televison & Video
2006 VOLVO FRONT LEFT PARKING LIGHT
Has the bulb socket been tested to see if 12 volts is present with lights on? If it is replace the bulb, if that doesn't cure the issue replace the socket. Also make sure the socket has a good ground.
Mar 13, 2012 | 2006 Volvo V70
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
How can i wire up a twin lamp conversion to my kawasaki kmx 125 as it has 4 wires coming out but i cant find were to plug them in on the bikes wiring loom
It depends whether its a twin lamp that uses one bulb for low and the other for high beam or both bulbs stay on through low beam and high.
Nov 25, 2010 | 2002 kawasaki KMX 125
Computer flashes tail lamp failure and my tail lights and liciense plate light all work. what is the problem?
Hello and welcome to Fixya.com.
Check to see if you have twin tail lamp bulbs on rear i mean when i say this two tail lamp bulbs fitted to each side,check to see if one of the bulbs has blown if so replace it this will correct your computor.
Best regards.
George...
Jul 23, 2009 | 1996 Jeep Grand Cherokee
Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
Jul 11, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
Electrical Supplies Logo
35 people viewed this question
Top Cooper/regent Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Cooper/regent Electrical Supply Expert? Answer questions, earn points and help others
