Question about Epson Stylus RX580 InkJet Photo Printer
Getting see documentation message
When I try to print it makes a grinding sound and then get the message to see documentation and the printer is locked up.
    Brigadier General:
  • 4,090 Answers
Sometimes this is just a simple trask of cleaning the ink off the rails of the ink carriage.try that first and see if it rectifies the grinding sound. also check that you have not got soemthing stuck in the cogs on the R side of the platten roller mechanism
Posted on Jun 23, 2009
I was in the process of making copies, when my Epson RX700 suddenly made a loud grinding noise. It then stopped working and displayed an error message: Scanner error occurred...Please see...
There are two drives in the printer. One moves the print head (cartridge) back and forth across the paper. Check to see if the "rubber band" drive belt is slipping or broken off. There is also a roller motor which feeds the paper. This has nylon gears which can make a grinding sound if one of the gears gets stuck. Make sure there are no pieces of paper stuck in the gears.
Mar 06, 2011 | Office Equipment & Supplies
Every so often when I try to print a document I
Try reinstalling the printer driver, make sure you uninstall it first.
Jan 10, 2010 | HP OfficeJet G55 All-In-One InkJet Printer
Printer makes grinding noise and not printing
sounds like the rubber band in side the printer has jumped a tooth which is why it is grinding bud have it repaired or get another
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Hp psc 2110 incorrect ink cartridge message.
Hi plabonne,
I hopped out to HP's support site for stats on your cartridge and found some info at this link:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=C8648A&jumpid=oc_R1002_USENC-002_HP%20PSC%202110%20All-in-One%20Printer&lang=en&cc=us
are you using an HP 57 Tri-color cartridge? HP printers work best with HP cartridges and often have problems with refilled cartridges. the grinding noise you're hearing makes me wonder if the cartridge isn't seated all the way in its little carridge (the plastic part that holds the cartridge). have you had a chance to slip teh cartridge back out and try gently slipping it back in again?
here's another link to try for info for this model of printer (HP's support site), with specifics about your error message about half way down the page:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu05206&dlc=en&product=79488
hope this helps!
-JW50
Nov 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Said error but when it prints it starts banging and then a loud sound (plastic jamming sound)
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to crunching grinding plastic sound for your Printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Please try the solutions that are mentioned in the below links.
Link 1:
http://tinyurl.com/3d2hgu
Once if you are done with steps that are mentioned in the web page. Check the issue. If the issue still persists then please go ahead with next solution.
Link 2:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00300328&lc=en&cc=us&dlc=en&product=79477&rule=46175&lang=en
If  the issue still persists, then you may need to service the Printer once to resolve the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 20, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Epson Stylus RX580 InkJet Photo Printer Logo
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
