Question about Denon DRA-395 Receiver
Denon 2312ci turns off and blinks red? What do I do?
Connection failed
This is a message from the AVR2312CI attempting to connect to the Internet through it's local area network Ethernet socket. Turn this feature off in the setup section if you do not need to connect. If you do want to connect, make sure you have a good connection to your router and, if necessary, make sure your security software is not blocking the connection. If that fails, turn off modem, router(s) and amplifier then switch on in the order:
modem,router(s) and finally your AVR2312CI.
That should solve your error message.
Regards, Don.
May 31, 2014 | Denon AVR-2312CI
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Denon troubleshooting
my denon s900w is blinking on and off. what do to fix the problem
Jan 03, 2014 | Televison & Video
No sound from internet radio
I assume you have connected your amplifier to your local area network so that you can access internet radio. If not, you need to connect the RJ45 ethernet port to your router, then log on to your router to confirm that the receiver is connected as a client. I have done this with my Denon receiver and it works perfectly. Please feel free to ask if you need further assistance. Cheers, Don.
Dec 07, 2013 | Denon AVR-2312CI
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Restarting avr-2312
I've had THE SAME PROBLEM ! Neither official servise, nor internet could help me. The solution was problem with POWER CABLE! When tested it by TESTER it was ok, with no sign of a problem. I've tested everithing byt nothing could help me :) After all test I've noticed that when I've touched the power cable the problem occurred. After changing the power cable everithin WAS GREAT.
Aug 13, 2012 | Denon AVR-2312CI
Denon AVR-1906 Reciever is not working. Was watching a movie and then it suddenly shut off. Now, the power light is blinking red. When I try to power it on again it starts to boot up but then turns off...
speaker terminal are short circuit,switch power off connect speaker properly then switch power back.
-the ventilation holes of the set are blocked-turn power off and make good ventilation around leave the set to cool and turn power back.
-the unit is operating at continuous high power turn it of and allow for cool down and switch it back.
Jun 01, 2008 | Denon Audio Players & Recorders
Blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
May 25, 2008 | Denon AVR-1906 Receiver
Denon DRA-395 Receiver Logo
37 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
