Question about Kenwood Nxr-810 Digital Uhf Repeater W/ Pwr Supply & Duplexer - -
Why are all my radios talking at once
All of us talking at once
    Problem Solver:
  • 20 Answers
You all need to take turns.
Posted on Oct 07, 2014
Kenwood 2 way radio
Advertising for various radios differs, and can offer some incredible ranges. The following is a good rule of thumb in the real world:
Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range.
Mobile radios, such as those mounted in vehicles, will generally talk "radio-to-radio" 8-10 miles depending upon the obstacles and the terrain.
Repeater Towers and/or Trunking: If your radio is programmed to match a local repeater or trunking system, your range will be determined by the footprint of that particular system. See your local dealer for details.
Consider your radio can talk as far as it can "see". If you are on a mountain top, your radio will talk far into the valley, and seem to have incredible range. So conversely, if you in a city with many obstacles, you may have a very short range.
Best regards.
Aug 31, 2012 | Kenwood TK250, TK350, TK353, TK430, TK431...
My Midland xtra talk lxt 320 is not working properly. Once I turned the radio on it just started buzzing. For some reason I can't turn it off. It also says rx at the top right hand corner. On my another...
Try replacing the batteries with a good set of alkalines. The standard batteries that come with these radios are of poor quality and get weak very shortly after purchasing these radios. The radios will have the symptoms you described when the batteries are weak. At least this has been my experience having these radios.
Jul 20, 2010 | Midland LXT310 2-Way Radio
I want to know talk range of Talkabout T5720
Advertising literature will sometimes give numbers such as "5 mile range". While this is possible in ideal conditions, it is not common in real-world situations. HEIGHT and PLACEMENT of the antenna determines the range of the radio. Example: Talking from a mountaintop you could talk far into a valley below, much further than the expected 2 miles. However, if you were to be in an congested city, you may only be able to talk a single city block due to obstacles.
To get the best range, use a well charged battery pack, wear your radio high on your body, and always hold the antenna perpendicular to the ground when using the radio.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Apr 08, 2010 | Motorola Talkabout T5720 (7 Channels)...
I HAVE a 1995 saab 900s and i need the code for the radio i do not have the manual.
my 1995 saab 900s actually has the code written on the casing of the radio once you pull it out
Nov 12, 2009 | 1995 Saab 900
My problem is i dont know how to work it?!
Here is a link to the user guide http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
First, we suggest checking to see the radios are on the same frequency, interference eliminator code and the Qt filter is set to off or zero. Once you have determined the radios are set alike, you should be able to use the radios by pressing the push-to-talk button when you want to talk, and releasing it when you want to listen to the other radio(s) talking back to you.
Oct 25, 2009 | Motorola Talkabout T5720 (7 Channels)...
1/2 mile range max
Advertising on these models is much like reading about a car's MPG, it must be in perfect conditions. Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range. Even the body fluid of the person wearing the radio on their hip will absorb some of the range. Talking from inside of a building to outside you might expect 1/4 to 1/2 mile. Good rule of thumb: Height and placement of your antenna determines range. The higher the antenna, the further you can talk. If you are talking from on a mountain top to a valley below you can talk as far as you can see. Increasing Range: Hold your radio perpendicular to the ground, not slanted like you would hold a phone. This problem alone could decrease your range 2/3s. Face the direction you are wanting to communicate. Don't shout CB-style, shouting reduces talk-range. Lastly, use good batteries. This will ensure your transmit capability.
Jun 08, 2009 | Radio Communications
The working frequency range for talkabout T6210
Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range. Even the body fluid of the person wearing the radio on their hip will absorb some of the range. Talking from inside of a building to outside you might expect 1/4 to 1/2 mile. Good rule of thumb: Height and placementof your antenna determines range. The higher the antenna, the further you can talk. If you are talking from on a mountain top to a valley below you can talk as far as you can see.
Increasing Range: Hold your radio perpendicular to the ground, not slanted like you would hold a phone. This problem alone could decrease your range 2/3s. Don't shout CB-style, shouting reduces talk-range. Lastly, use good batteries. This will ensure your transmit capability.
May 30, 2009 | Motorola Talkabout T6210 (14 Channels)...
I can hear my buddys talking to me on my cb radio but once i try and talk to them it just sqweeks
Usually a squeal is feedback from a very high SWR or a mic wiring issue. Have the SWR tested and try another mic. Make sure it has the proper wiring. Just because a 4 pin mic fits in the jack doesnt mean it has the same wiring configuration. Also if you run an amp dont wire the amp and radio to the same location. That can creat a ground loop and cause squeal, but not always.
Mar 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
2-way radio
I have a model 1018 bellsouth 2-way. Are you talking about the tone that lets the other person know it's okay to talk? If so, turn the unit on---press the (fun) function button until you see the RGB abbreviation flashing. ***about three times on mine***** You should also see displayed ---ON---. Using the channel changing button---press it once. The ON should change to OFF.
Hope this helps. Have a great day.
PJ
Nov 07, 2007 | BellSouth 1040 2-Way Radio
Kenwood Nxr-810 Digital Uhf Repeater W/ Pwr Supply & Duplexer - - Logo
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
