Question about SkyGolf SkyCaddie SG3 And SG4 USB Power Y Cable SG3_4USBPWRCBLE
Stripped screw that attaches the charging cord.
The screw will not stay in place when attached the charging cord
How do you attach a back license tag to a 2007 PT Cruiser?
go to a hardware store and get some toggle bolts that will fit through the holes. easy peasy
Dec 23, 2017 | Cars & Trucks
How do I open the philips bt3500 bluetooth speaker to repair/replace the charging port?
I opened mine by pulling off the back cover, it is clicked in. then I removed the six screws that appear. Then you can press out the front
Oct 05, 2014 | Audio Players & Recorders
Where do i plug in the power adaptor, so I dont have to worry about using the choke when the bike gets cold?
Instructions
    • 1 Fotolia.com"> install-motorcycle-cigarette-lighter-1.1-800x800.jpg If the battery is installed under the seat, loosen and remove the hex bolts holding the seat in place, and remove the seat from the motorcycle. If the battery is mounted under a side battery cover, pry the battery cover from the motorcycle to expose the battery.
    • 2 Strip one-half inch of insulation from one end of the black wire and one end of the red wire. Place a ring terminal over the stripped ends of the black and red wires, and crimp the terminals to the respective wires.
    • 3 Place the positive wire from the weatherproof socket into one of the holes in the first splice connector. Place the free end of the red wire into the splice connector, and crimp the connector to make the electrical connection.
    • 4 Place the negative wire from the weatherproof socket into one of the holes in the second splice connector. Place the free end of the black wire into the splice connector, and crimp the connector to make the electrical connection.
    • 5 Loosen and remove the retaining nut on the positive battery terminal. Place the ring terminal attached to the red wire over the terminal screw, and replace and tighten the positive battery terminal retaining nut. Loosen and remove the retaining nut on the negative battery terminal. Place the ring terminal attached to the black wire over the terminal screw, and replace and tighten the negative battery terminal retaining nut.
    • 6 Route the power outlet to a point on the frame below the rider, and attach the outlet to the motorcycle frame using a cable tie. Use the remaining cable ties to attach the excess wire length to the frame of the motorcycle. Reinstall the battery cover or the seat when finished.
Instructions
Instructions
rate these after reading
Jan 16, 2013 | Motorcycles
HP Pavilion Dv6000z will not turn on
Florida Bob,
Battery is part of the power/charging circuit. As you have found it needs to be in place; kaput or not.
Believe your problem to be Power MOSFET's.
This will explain why,
http://www.fixya.com/support/t15330613-hp_pavilion_dv8_not_starting_up
(The Mayohardware article)
Now you may know what is wrong, and where to get replacement parts, and how to replace.
This is the HP Support link to the free Service Manual,
Main Support page for the HP Pavilion dv6000z Notebook PC,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3224052
Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3224052&
In the list you want the blue -
HP Pavilion dv6000 Notebook PC - Maintenance and Service Guide
USE an ESD wrist strap.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
http://www.ebay.com/itm/65W-CHARGER-AC-ADAPTER-FOR-HP-Pavilion-dv1000-dv2000-dv5000-dv6000-146594-001-/221082152535?pt=Laptop_Adapters_Chargers&hash=item337985ee57
18.5 Volts (DC)
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 09, 2012 | HP Pavilion dv6000z Notebook
I have a desktop pc emachine w3050. need to know if the vga cable permanetly attached
I am sorry I do not understand your problem, vga cable technically cant be permantly attached. If it is attached in the back and it has the two screws that are located beside the main cord hub then you can unscrew them, (righty tighty, lefty loosy), and you should be able to remove the cable. If you are trying to connect the cable then you could make it somewhat permanent by screwing the screws in and making it sturdy.
Another thought just came to me, if you are referring to not being able to screw it out then the screw handles could possibly be stripped, which of course you could use pliers to get a good grip and still probably screw them out.
Hope this helped.
Feb 07, 2011 | E-Machines eMachines Desktop PC
Have used 1981 Coleman pop-up camper and the mechanism that raises the camper up is stripped. Either need manual for 1981 Coleman pop-up or any idea where to get the part to fix problem. It's the screw...
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
Sep 21, 2017 | Coleman 10' X 10' Sundome Tent 9160K101
Screw Size to install electrical cord
they should be what is called a 10x32 screw. you should be able to get these from any hardware store. not at home depot or lowes, but like an ace hardware. they will know what you are talking about.
i would guess that someone lost your original screws. if not then you might be having problems because the screws got stripped out when trying to change the cord or hook up a new one. if that happend, then you will need to replace the nuts also. get them at the hardware store too.
it may not be easy but you will save alot of money if you can do this yourself.
Dec 31, 2008 | Kenmore 659 Electric Dryer
Cannot attach tripod plate to scope - stripped receptacle
Hardware stores should have thumb screws in different sizes and thread lengths ... box stores , local hardware ....
Jun 11, 2017 | Minox MD 62 ED W 62213
SkyGolf SkyCaddie SG3 And SG4 USB Power Y Cable SG3_4USBPWRCBLE Logo
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
