Question about GE Refrigerators
Ice Maker The icemaker in my GE Profile refrigerator keeps freezing up and not dispensing ice.
    Brigadier General:
  • 4,090 Answers
This requiers inervention by a refrigeration mechanic to replace the control thermostat
Posted on Jun 23, 2009
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
New ge fridge ice maker stopped producing ice
check filter or waler valve may be is the icemaker call service
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PDS22SIS ice maker problem
on the ice maker press and hold the size selector. This will put the ice maker into a test mode and it should cycle through. If it doesn't work your problem is with your icemaker.
Sgt 48
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
