Question about Music
Yamaha ydp s30
A tooth picker fall into the keyboard of a Yamaha YDP S-30. Is it easy to open and fix it by myself?
marinelvr18
  • 5 Answers
SOURCE: Sticky Keys for Yamaha Digital Piano YDP-121
have you tried using the can of air. you can get it at almost any drug store walmart or kmart. just spray the can of air between the keys and they should become unstuck.
Posted on Dec 13, 2008
  • 5603 Answers
SOURCE: Digital Piano has sticking key
Typically LOTS of screws... concentrate on those around the edge. USE GREAT care and force nothing when removing the cover...and great care of cables between the cover and the base. Mark the cables so you remember the direction they attach.
When you get edge screws out, then gentle lift and see where it seems to be held...
Some of these synths have 50 to take out to get apart. MOST are in plastic bosses and keep track of the size and length as you can put too long a one in the wrong place and crack the boss.
I use a compartmented plastic tray to keep the screws in order.
Posted on Jan 06, 2010
  • 3 Answers
SOURCE: how can i replase the
There are step by step instructions under another Fixya thread here: see solution #2
http://www.fixya.com/support/t8881187-1_key_not_spring
Posted on Jul 02, 2011
  • 3 Answers
SOURCE: I have a Yamaha ydp-121 88-key piano. It has 3
I wrote up and photographed for my similar YDP, see solution 2 under this post:
  • 5603 Answers
SOURCE: My yamaha ydp-160 sounds like
On SOME Yamaha pianos, there is an electrolytic capacitor 1mfd/50v that becomes leaky and causes this. On those with the particular main board the capcitor is at location C94. On other pianos there are other caps that bypass the wire from the pedals that are ceramic. Likely one of these has shorted. There is also a possibility that the pedal contact has shorted. Test for this by unplugging the pedal cable. If it still sustains, then problem is internal. Unless you are adept at electronics this is NOT a DIY repair.
Posted on Aug 07, 2011
Dissembling YDP- 131/YDP-213 keyboard to reveal key contacts?
To remove keys you need to remove screws on the top row of the keys, turn over, remove circuit boards that run the length of the keyboard, remove rubber contacts. Keys will then un-clip the circuit boards hold the keys in place.
If you need more info admin@beckettsmusic.co.uk
Oct 17, 2016 | Music
How do i replace one key on Yamaha YDP161?
A YDP uses the same key type as a basic Yamaha Clavinova. As you have stripped the keyboard to reveal the keys take a look at the end where the key hinges. There will be an arrow pointing to one side. You will need to remove att the screws holding the key base (black plastic ) to the wooden base. Slide the whole keyboard back a couple of inches, push down where the arrow points between the keys, the offending key will pop up. Slide forward and jiggle out. Replace key. reassemble. If the tag on the back of the old key has snapped off remove the piece of debris that might be there before refitting.
dan@beckettsmusic.co.uk
replacement keys can be found online
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17431
Jun 07, 2014 | Yamaha YDP-161 Arius Graded Hammer Piano...
My yamaha ydp-160 sounds like my pedal is stuck down. All keys are sustaining all notes. Is there an easy fix?
Aug 07, 2011 | Yamaha yDP S31 ARIUS Console Piano
Ydp 223 some keys are starting to stick to on the downstroke when not struck with a perfectly vertical stroke. varying degrees of affliction. instrument 2 years old thanks for any help
Yamaha keyboards can be prone to sticking keys due to the rear part of the key cracking around the return spring - if this is the case the only solution is replacing the affected key modules. However this problem generally only occurs with long term use by very physical players.
Otherwise the problem may be caused by a build up of dust / fluff between adjacent keys - try raking out the spaces with a thin piece of fairly rigid plastic (maybe a credit card might work?)
Feb 24, 2011 | Yamaha YDP223 Digital Piano
My Yamaha YDP-121 digital piano has a key that is slow to pop up once pressed...the key will still produce a sound but the key becomes "sticky" and stays pressed, sometimes requiring manually lifting the...
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
Nov 29, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Yamaha ydp-121 88-key piano. It has 3 keys that are sticking. Any ideas how to fix it?
Oct 20, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Dec 07, 2008 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
