Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Hoover dual v steamvac will not dispense soap solution through the floor or upolstery attachment, rinse does dispense
FH50040
reddevil6
  • 1673 Answers
SOURCE: I have a hoover steamvac
One cause is that the recovery tank lid isn't on correctly and not sealing. If there is a foam filter on the inside of the lid, make sure it has a 1/4 in. gap from the top of the lid. There is another filter, from the bottom, it has a red frame, pull it out far enough to clean it. May have a bad turbine, or the shaft on the top of the brush block broke off. You have a 1 years warranty on this, I would take it in to a warranty repair shop and get it repaired.
Posted on Aug 10, 2008
  • 37 Answers
SOURCE: hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
Posted on Sep 24, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at lostnhisblueyes@aol.com
i took off so many more screws than i needed to to get this figured out so dont do that.
Posted on Apr 03, 2009
  • 7 Answers
SOURCE: Instructions on how to put attachments on hoover
Remove solution tank.
Remove hose from storage rack.
Remove recovery tank and lay cleaner flat on floor. Remove lid,
Now, remove front panel from recovery tank by sliding it straight up.
Take your hose and slide the U-shaped end (converter) into the place where you removed the panel. Slide halfway down opening until it is firmly in place.
2nd step: You should have a tube with a "plug" on it hanging from the converter end. Open door on hoodl abeled "Stair upholstery/Cleaning Connection". Extend black tabs by pulling tan collar toward tube. Press connector collar down firmly to ensure that it is fully connnected.
It's sort of like a childproofed plug and socket. Pull back on the collar and push in the olug. Not hard at all once you've done it the first time.
Make sure you put the lid on the recovery tank correctly so you have suction. Attach whatever brush you want to use on the other end until the tab locks into place.
Sometimes you have to bleed the air from the line by turning on the cleeaner and letting it **** against your hand or hard surface for 15 seconds before its ready to use. This gets the solution to flow to the tool.
Posted on Aug 06, 2009
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover v2 steam vac F7430-900 the water container will not dispense water only soap yes, any idea to fix this problem?
This is most likely due to a problem with the solenoid on the rinse side not opening. The solenoid may require replacement.
Jan 17, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
Will not dispense water on rinse cycle
Upholstry brush will not dispense water, the suctin works and the floor cleaning part all works.
Aug 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover STeam Vac Dual V. Replaced the water tank-no problem. but water still pours out through the bottom. when idle, when off, when running. dont need to press the lever. Help!
Te dual V models have an electric pump and 2 solenoids that control the soap and water to dispense. The problem you describe, sounds like the water solenoid is stuck open. and would need to be serviced by a repair shop.
Oct 07, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water will not dispense through the attachment hose and come out of the brush in order to clean stairs
The Dual V has pumps and solenoids that control soap and water flow. This type of problem requires shop service.
Jul 19, 2009 | Hoover F7431-900 SteamVac Vacuum
Part broken to dispense cleaning solution.
Most of the time you can only get the tank. part number 42242134
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do i attach the upolstery attachment?
Go to www.Hoover.com Click on carpet cleaners. Click on steam vac all terrain. Click on Learn more. Click on Download Instruction manual in pdf. It explains all. The hose is attached on the front of the recovery tank. under the hoover symbol.
Jan 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
77 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
