Question about Lexmark E234 Laser Printer
How to turn off paper jam light on E232 - Lexmark E234 Laser Printer
  • 163 Answers
SOURCE: Lexmark E232
oh my GOD ,PLESE OPEN ITS ELECTRONIC BOARD AND REINSTALL IT PROPERLY
Posted on Sep 19, 2007
guide2u
  • 461 Answers
SOURCE: printer not printing
you might need to check your driver if it is install correctly for the correct OS, i'm not sure what OS you are using but below link might be helpful to help solve your issue
http://etech.maiila.com/?p=42
all the best..
p/s please rate me...
Posted on May 29, 2008
  • 4 Answers
SOURCE: PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Posted on Mar 08, 2009
SOURCE: PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Posted on Mar 19, 2009
  • 13 Answers
SOURCE: Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Posted on Jun 04, 2009
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Hi, My Lexmark E232 printer is on but will not print. The light second from the bottom is orange. Help!!
That second from the bottom orange light indicates a paper jam. Press Continue to resume printing once all the jammed pages are cleared from the paper path. Press Continue twice quickly to see the secondary error code. See "Secondary error codes" on page 69 of the user manual for more information.
Here's a link to the manual: http://www.lexmark.com/publications/pdfs/e230/eng/ug.pdf
Mar 21, 2011 | Lexmark E232 Laser Printer
I have a MacBook, and a Lexmark E232 laser printer. It has worked fine for several years but all of a sudden when I try to print the light for the light for a paper jam comes on. I have cleared it, and...
The problem is that the printer thinks that there is a paper jam inside the printer. What could be happening is that there was a paper jam the paper was pulled out but the actual sensor that detected the paper probably got damaged, either broken or malfunctioning. In this case try the following, turn off the printer and open the front cover. Then press and hold down the two front buttons while having the cover open and turn the printer on. Then wait untill the bottom light stays on solid then release the buttons that should reset the printer. If after that the paper jam error does not go away then you are probably looking at a damaged sensor. To fix that you will have to take it in to have it service.
Hope it helps.
Mar 19, 2010 | Lexmark E232 Laser Printer
Jun 01, 2009 | Lexmark E232 Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
PAPER JAM
Aug 22, 2008 | Lexmark E232 Laser Printer
Light error
You should contact Service Center regarding this.
Jul 25, 2008 | Lexmark E232 Laser Printer
PAPER JAM
Jun 26, 2008 | Lexmark E232 Laser Printer
Printer not printing
all the best..
May 29, 2008 | Lexmark E232 Laser Printer
Lexmark E232
Sep 19, 2007 | Lexmark E232 Laser Printer
Lexmark E234 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
