Question about Husqvarna Garden
Husqvrana tiller wont run after choke is turned off
5 Suggested Answers
  • 8 Answers
SOURCE: Rough Running
It depends on the type of engine but it sounds like your carbeurator is running lean. there is and mixture adjustment screw on most of the older models, alot of the newer carbs. are pre set to emission standards. try a fuel additive called sea foam, this product has solved solved many of my fuel related issues.
Posted on Nov 16, 2008
  • 10865 Answers
SOURCE: tiller wont start
It is probably gummed up. go to an autozone or similar store and get some gum out spray for the carbeurator and some for the gas.
Posted on Apr 06, 2009
panilling9
  • 284 Answers
SOURCE: I have a sears garden tiller model 825 that starts
Fuel related issues
Do you have clean and fresh fuel?
Remove carb and bench it and dismantle and use carb. cleaner and air and find all orifices and clean and blow out dry reassemble and reinstall
Check for proper fuel delivery from fuel tank
if you have a fuel filter replace it
Posted on May 30, 2010
Testimonial: "Thank you very much, that was the problem, works fine now."
  • 208 Answers
SOURCE: My tiller won't run after cold start, after choke
Watch this video and do it.
http://www.alamia.us/mantis_parts_s/148.htm
Posted on Feb 20, 2011
Honda cg160 tiller the engine was running rough With choke all the way in, fine at halfway. then stopped moving forward,moves but no strength to till. What's wrong??
while your choke is out your engine is getting too much petrol . if it wont run well with choke in then its not getting enough. there is a small screw on the side of the carb ( air mixture ) they are usualy ( from screwed right in ) 1 and a half turns out, try with 1 and a half turns out start engine and adust either way so it idles nice ( try and warm engine up first ) also if you can't get it to idle you might have to strip card off and clean it ...hope this helps
Apr 23, 2015 | Honda Garden
Why Tiller cranks but will not run when you need it to till?
If you don't have a manual, could can read/download it at this link.
If the engine stalls under load, the mixture may be too lean. There should be a mixture screw on the carburetor. Note its position, and turn it counter-clockwise 1/8 of a turn to see if there is any improvement in engine performance. Repeat this but don't exceed about a half turn.
The tank has a vent and this should be kept vertical under the cylinder cover in the small "pocket" in the cylinder cover.
Lack of power can be caused by a dirty air filter or blocked muffler screen.
See the article below for troubleshooting 2-cycle engines
String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
May 30, 2014 | Mantis 2-Cycle Tiller
I cannot remember how to start my tiller
This Could be a problem? Turn the fuel on, place throttle lever to choke, prime if available and pull cord. when running move throttle to run. Good Luck, your gonna need some!!!!
Apr 20, 2011 | Mtd Products Yard Machines 158CC Tiller
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
My briggs and stratton 3hp edger
not getting gas check plug gap
Jun 23, 2009 | Garden
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Garden Logo
44 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
