Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Were is the ariel output? - Vizio P50HDTV10A 50 in. Plasma HDTV
    Genius:
  • Vizio Master
  • 1,039 Answers
There is an antenna input . it is a coax connection. There is no ariel output.
Posted on May 12, 2014
Were is the Ariel output
You have bought a monitor NOT a tv. You need to buy/obtain a separate tuner box for tv signals then connect your tuner box to your monitor.
May 10, 2014 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Tip
How to change a broken electric ariel on a saab
my electric Ariel stopped working and I was quoted £87 to replace it I bought a replacement on ebay for £13 its a simple fix just undo the Ariel nut on top of the car rear wing get someone to sit in car and push radio button old ariel starts to come out simple assist it until it has completely come away from car put new lead into hole then get person in car to switch of radio and feel the ariel start to be pulled back into place be carful to keep it straight as it enters then replace locking nut total time less than 5 mins cost £13 plus one person to assist easy fix
on May 07, 2015 | Saab 9 Cars & Trucks
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
Mar 17, 2013 | Ariel Platinum AM128JDCLZ Whirlpool...
On my cb when i do a radio check it says rf power output fail what does this mean
RF Power is the power that transmits the signal from your radio. RF power output fail means that the radio is not putting out a signal. This could be caused by a high SWR but more likely it's caused by the a fault in the transmitter part of the CB.
If this is a newly installed CB it's possible that the ariel is not connected properly. This can sometimes happen if the co-ax wire, that connects the ariel to the radio, has badly soldered joints or short circuits. These can be checked with a multimeter or continuity tester by checking that there is not a connection between the centre pin of the plug and the outer sleeve of the plug. There should be continuity between the centre pin of the co-ax at the radio end and the centre pin at the radio end. If the ariel end is sealed you may be able to check it against the ariel instead if it's metal.
If all these checks pass you can test that the CB is transmitting power by using an SWR meter and a 50 ohm dummy load. Connect the SWR meter to your CB (where the ariel normally connects) and connect a 50 ohm dummy load to the other end of the SWR meter using a short co-ax lead. When you transmit with the radio the dummy load acts as an ariel, though you won't be able to contact anyone with it. Set the SWR meter to POWER FWD and it will show if any power is being transmitted. If there's not then the fault is in the radio and it will take a technician to repair it. If the power is going forward then the fault is with the antenna or the connection to it. Dummy loads and SWR meters can be picked up fairly cheaply on ebay if you don't have one or if you know any radio amateurs (ham radio operators) they should have them and would probably lend you them.
I hope this helps you with your problem.
Apr 11, 2012 | Cobra Radio Communications
Do i need ariel for cobra MR F55 EU radio
? I assume you are asking if you need an ariel antenna for this radio in order to receive and transmit? if that is the case then yes you do, Any radio requires a matched antenna in order to transmit, if you were to transmit without an antenna, most of the RF energy will transfer back into the radio and over heat "burn out" the output transistors. always make sure to have a proper antenna connected before transmitting on any radio.
Jun 19, 2011 | Cobra MRF55 2-Way Radio
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Kenwood micro hifi model rxd-m33v ariel output
You need a 75 Ohm standard aerial connector to 75 Ohm miniature RF connector adapter to fit the socket..
Jan 18, 2018 | Kenwood Audio Players & Recorders
Can't Receiver ( No Signal )
I WOULD SUGGEST THE ARIEL BREAKING DOWN, OR AN INGRESS OF WATER IN THE COAX CABLE. IF YOU NO SOMEONE WITH THE SAME UNIT TRY YOUR UNIT ON THERE ARIEL.
Feb 27, 2008 | Furuno GP32 GPS Receiver
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
49 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
