Question about Tascam DP-03 DP03 8-Track Digital PortaStudio Recorder
What do you do when you see card full error after recording only 6 tracks
When I try to burn recorded track, shows a message CD full when I check remaiing spcace, it shows full available
i think the maximum capacity of a CD is between 750MB to 850MB . since the error message is CD full better check the amount / volume of data to be transferred to your CD .
Aug 27, 2014 | Cameras
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
Tascam DP02CF not responding to anything what should i do nest please?
That's an 8-track recorder that records to a compact flash card. It is not a minidisc recorder.
Oct 01, 2012 | Tascam Dp-02cf Digital 8-track Recorder
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
Aug 30, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
My DP-02CF comes up with no free disk space even though i've bounced everything together and ive still got 6 tracks left. how can i stop this from happening
This is just a suggestion - back up the track to a PC using the USB port and reload and reburn on a new disc. Sounds like you may have a bad file and or disc. And by the way you worded this, has this happened before? Make sure the activity light is out and your tracks have been recorded fully before turning the unit off or you will get "end of file" errors.
Len
Nov 01, 2009 | Tascam 2488 Portastudio Multitrack...
Not reading flash card, says "card error! error 08"
This is due to the corrupted data in the card,
Please get your Card formatted by any external medium. It will work and yes, please take care to plug-in the devices to appropriate port, it can harm your instrument permanently.
Hope this helps.
Thanks.
Mar 15, 2009 | Fostex MR8-MKII - 8 -Rack Portable Compact...
Tascam DP-03 DP03 8-Track Digital PortaStudio Recorder Logo
29 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
