Question about Suunto Pc Pod Wireless Transmitter
Where do I find a suunto pc pod driver for t3?
Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
RTFM
Suunto Core User Guide
ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
How to Set Up a New Suunto Core - YouTube
? 6:49
https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
[PDF]Quick Guide - Trekkinn
www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
Jun 17, 2017 | Suunto Watches
Suunto t3-changed battery and Suunto t3 is displayed at the bottom of the dial but no functions work.
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Aug 07, 2013 | Watches
I have Problem with the Suunto Pc Pod Wireless Transmitter Driver for Suunto USB PC pod with windows 7...
I found out that this is because the wrong drivers are installed.
When you install the suunto software the usb drivers are stored under C:\Program Files\Suunto\USBDriver. This contains more than one driverset. See if you can find this.
Then go to Control Panel\Hardware and Sound\Devices and Printers and find your Suunto device. You probably have only one device and will miss Suunto Usb Serial Port.
Now open the deve and change the drivers, via manually select . Select browse and go to C:\Program Files\Suunto\USBDriver. Press Enter. The program will see that there is more than one driver set and offers you a choice.
Previously it has automatically selected the newest one, which unfortunately did not work in my case. Select the oldest set and the program will install the drivers,
Now you will see in Control Panel\Hardware and Sound\Devices that you have 2 devices suunto pc pod and suunto usb serial port. And the program will run and be able to connect to the watch
Good luck
Timco
Dec 13, 2010 | Suunto Pc Pod Wireless Transmitter
I have a suunto pc pod. my suunto t3d watch can connect to the pod but the pod cannot connect to the software installed (training manager lite) since my pc cannot find any drivers to install for the...
Good luck
Timco
Oct 02, 2010 | Suunto Pc Pod Wireless Transmitter
Driver for Suunto USB PC pod with windows 7 64-bit
I had a problem with the drivers for W7 32 bit, maybe it's the same problem:
Good luck
Timco
Aug 02, 2010 | Suunto Pc Pod Wireless Transmitter
Lost instruction to a digital/analogue pod watch
This watch appears to be made by "Suunto" and if you go to their web site, you should be able to find your watch detailed there.
If you then go to "support center", you will see "download center and user guides.
Jan 03, 2010 | Watches
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
Changing metric to Imperial on Suunto Vector
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
It's in the manual. I did it on mine.
Dec 25, 2008 | Suunto Vector Wristwatch
Suunto Pc Pod Wireless Transmitter Logo
29 people viewed this question
Top Suunto Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Suunto Cycling Expert? Answer questions, earn points and help others
