Question about Samsung M7E HM321HI 320 GB SATA Hard Drive
SAMSUNG HM321HI - Samsung M7E HM321HI 320 GB SATA Hard Drive
Smart failure predicted on hard disk 0: samsung hm321hi - (PM) Says press f1 to continue.. But nothing happens after i press F1.. Hard reset already tried.. When i turn the laptop on, it says "system...
Have you tried starting in safe mode or connecting the hard drive to another computer as a 2nd drive and accessing it that way and trying to repair and virus check
Dec 01, 2017 | Computers & Internet
Smart failure predicted on hard disk 0:SAMSUNG HM321HI-S1 lik message coming when i on the system.. so wat wat to do now?
Save all of your files to an external storage device (Flash Stick or desktop drive) and the replace the hard drive. Do it quickly, because there is no time period given before it fails. And it will.
Jun 24, 2012 | Dell Computers & Internet
OPERATING SYSTEM NOT FOUND
Hello
As per my experience about your problem it sometimes occur when the power supply connector of your hard has loose connection or the sata cable connector loose. Try to check in the bios set up if the hard disc is in there. And check the connector are tightly connected to there pins and see to it that all the pins are connected to the connector of your motherboard and hard disc are connected properly.
Hope this solve your problem.
Jul 26, 2011 | Samsung HM321HI Samsung 25 320GB 5400RPM...
My not show on pc
samsung hard disk module hm321hi when i connect it to cpu by data cable it get beep sound & not work....what happen to it,,,,,,,
Jun 22, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
My HM321HI is not being reconazed, please help me with this
open your start menu, and right click computer and go to manage. in the computer management mmc, go to disk management. From the disk management window, you will be able to see if your drive is actually being recognized by your computer. if it is and isn't showing up, format and assign a drive letter
May 09, 2011 | Samsung M7E HM321HI 320 GB SATA Hard Drive
Windows detected a hard disk problem
Hard drives fail very often in computers. You can sometimes save your personal information by removing the hard drive and installing it in an external enclosure, and then accessing the drive by usb from another computer.
SATA hard drives are low priced and very easy to replace. You can order a new one at Amazon or NewEgg.com. Make sure you are getting the correct size (desktops accept 3.5" drives and laptops use 2.5" drives).
May 05, 2011 | Samsung M7E HM321HI 320 GB SATA Hard Drive
Samsung M7E HM321HI 320 GB SATA Hard Drive Logo
99 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
