Question about Maytag MSD2651 HE Side by Side Refrigerator
Maytag MSD 2556 AEW side by side
My refrigerator not cold any more, It have been cotrol board burnd out. I do not know It may fle on leak or not, because I press the pin that charged flee on it come out very weak of Gas, I can chage it by R 134 A that use for automative. Please give me an advise.
Thanks
VN
    Sergeant:
  • 288 Answers
Its hard to understand you, but check the compressor to see if it is running, then the condenser fan (if it has one) followed by the evaporator fan. if all these are running you may have a freon leak as most refrigerators do not come with access valves, someone had to install them for some reason.
Posted on Nov 04, 2007
Fridge/freezer leaks water
This is not very common. If you get water coming out of the ICE maker when you press the WATER dispenser, then the thing I would check first is the solenoid controlled water valve. It might be sending water out both legs at the same time. BUT if you have had work done on it lately, I would suspect that someone didn't get the electrical leads onto the control board correctly.
Jan 15, 2012 | Maytag Refrigerators
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
Maytag MSD 2756 DE The freezer is working the the fridge is not getting cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have an MSD 2756 AEW side by side, the fan in the freezer is blowing but it is not cold air so neither the freezer or fridge is cold. Do you have any idea what the problem could be?
The first thing I would do is remove the cover on the back of the fridge and check if the compressor is running. If it's not, then it could be the start device.
Remove the power from the fridge, pull out the start device from the compressor and shake it. If you can hear something inside is moving, replace the start device and the refrigerator will work fine.
Thanks for contacting Fixya.
Jul 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
How do i get my flap to my freezer back on
u remove the tray that catches the water behind there remove the screws then the front will pop off giving u access to the flapper door to see if it needs replaced or just popped out
Mar 21, 2009 | Maytag MSD 2655 HES 26 cu. ft....
Sider by Side problem
If the "relay" is the bimetal clipped to the top of the coils , then the adaptive defrost timer is bad . Pt # 61005988 .This small electronic board , is located in the control panel .
Nov 02, 2008 | Maytag 23 cu. ft. Side-by-Side...
Defrost Problem
the first thing to check is the defrost heating element, then the defrost limit switch, if good, then its probably the main circuit board.
Sep 12, 2008 | Maytag MZD2766GES Side by Side...
Maytag MSD 2756GE
Fully defrost this unit. Leave it open and off two about two days. Clean the condenser. Open the back and find the compressor and the largest pipe on it. Start the unit. It should frost and flash off to either wet, ice or dry in 5 minutes. If it stays frosty, call for warranty service. No idea what the snapping is.
Dec 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
Freezer is very cold refrigerator is warm
you have a defrost problem. could be your defrost heater or your defrost thermastat or i belive yours is a newer one with the electroic defrost timer
Jul 02, 2007 | Maytag MSD 2655 HES 26 cu. ft....
Maytag MSD2651 HE Side by Side Refrigerator Logo
164 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
