Question about GE JBP80 Electric Kitchen Range
Ge profile JBP90 control panel where is it - GE JBP80 Electric Kitchen Range
  • 93 Answers
SOURCE: control panel
If this is a smooth top the vent for the oven comes out right below the control panel
Posted on Jul 18, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Convection oven - 3 buttons on the
No schematics on line.
Take the key panel ribbon out of the connection to the control board and clean the end off with a pencil eraser. (some contacts are on one side, some on the other) Reistall and test. That takes care of the problem about 50 % of the time. If you still have the problem, replace the key panel.
Posted on Jul 25, 2009
  • 38 Answers
SOURCE: GE profile XL44 code F7 & FO readng on
Turn the circuit breaker off at the switchboard for a minute then back on again. This may reset the electronics.
Posted on Nov 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE JBP90 Gas Range is not holding heat very well
Your posted model is for an electric stove. Your question pertains to a gas stove. 2 things to look for: The most common of which is a weak ignitor. The second most common being a faulty sensor. Since you made no mention of a fault code I am going to assume the problem is the ignitor. For ignition to occur the gas safety valve has to release the gas to the burner. In order to do it the resistance on the ignitor must change. Over time the ignitor gets weak. One way to tell is by looking at it. It should be so bright you cannot stare at it very long. If it appears to be a dim orange AND you can bump the stove and sometimes get ignition then replace that ignitor.
Posted on Aug 17, 2010
vetteman3002
  • 2299 Answers
SOURCE: just installed new control panel
Normally the bake/probe flashing happens when you plug in the probe. If you don't have the probe plugged in, then double check that your wiring connectors are plugged in properly on your new board or that the wires to the probe connector are not shorted. Make sure that the probe is plugged in all the way. Unscrew the retaining nut, then unscrew the two sheet metal screws holding the housing in place, then give the probe connection a gentle tug to ensure that it is still properly connected.
Posted on Dec 22, 2010
Oven will not turn off and turns on, on its own
Either bake element is grounded out or control / clock is defective
Nov 03, 2017 | GE JBP90 Electric Kitchen Range
My ge range profile oven probe alarm sounds for no reason
Hey there Mic Bish.First let me say, that's a quality appliance you've got on your hands there, so congratulations!The thing is with that particular model, it was made in a factory in China near a haunted wood. There have been unconfirmed reports about spirits finding their way into the machines. What you've got on your hands there is a ghost, locked in a battle between accepting it's fate, and trying to return to the land of the living. Scary stuff!!!Mr Muscle have a new spray to deal with this. You'll find it in the cleaning aisle of your local convenience store.Hope this helps,Kind Regards
Oct 24, 2011 | GE JBP90 Electric Kitchen Range
GE JBP90 Gas Range is not holding heat very well in the oven. Takes ages to heat up to cook a pizza. When oven is on, heat pours out from under the control panel. I suspect mice have messed up the...
Aug 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JBP90 Electric Range - keypad not working
Hi-  If everything worked when stored, problem could be simple. The keypad is linked to the computer with a ribbon connector. The plug may have gotten corroded a bit in storage. Try this first: Unplug power. Remove back panel to access control. Remove four screws holding control. Unplug and inspect connector. Clean with a toothbrush and compressed air if you have it. Plug connector back in, re-assemble, and see if touchpad works.  Let me know if this info helps.  Have more if needed. - Ed
Mar 18, 2010 | GE JBP90 Electric Kitchen Range
I have a GE stove, model #JBP90, with a burned out element (it appears). How do I take the top off and replace the element?
if the element heats a lil bit its okay elements either work or dont, i woould check your switch before hand those elements rarely go out because they are not exposed to anything. once you get that console looseened or removed the top will pop off... check around the console or control look for some type of screws maybe endcaps covering ends or screas on back may have to remove knobs and lossen screews their as well.... you can go to sears.com and look at a parts breakdown for your model go to parts and service section, parts direct section hope this helps
Feb 03, 2010 | GE JBP90 Electric Kitchen Range
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
OVEN DOOR LIGHT SWITCH
These instructions apply to my GE Profile JBP90 but other brands and models are similar.
1. DISCONNECT THE UNIT FROM ITS ELECTRICAL POWER SOURCE!
CONFIRM POWER IS DISCONNECTED BY OBSERVING DISPLAY GOING DARK
In your case this may mean turning off the 220V double circuit breaker or unplugging the unit cord from its power outlet.
2. Open the oven door
3. Remove the two screws under the front edge of the stove cooktop on the far left and right
4. Gently raise the cooktop 4 or 5 inches and prop it open with a small cardboard box
5. Find the door switch wire and gently pull the switch connector off
6. Remove the switch by squeezing the two metal spring tabs toward the switch and pushing the switch out toward the front
7. Inspect the switch. If its like mine, it may look a little melted and smell burnt.
8. Find a new switch online or at your nearest parts distributer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212235
9. Installation is the reverse of above steps.
Good Luck!
Jun 25, 2008 | GE JBP90 Electric Kitchen Range
GE JBP80 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
