Question about Peg Perego John Deere Gator HPX
Peg perego gator dump bed broken - Peg Perego John Deere Gator HPX
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Could you please expand a little on when you say its broken? lots of these are assembled wrong with the rear black plastic pieces on backwards
Posted on Aug 15, 2017
  • Anonymous Aug 15, 2017
    see still answering gator questions from years past
  • 156 Answers
SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: I have a peg-perego polaris four wheeler. One
I would take off the wheel that is not spinning and see if the wires have come loose.
My grandson had a polaris 700 and one of the wires had come off.
I needed a gearbox 3 days later (go figure) and I got it at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-batteries.html
These guys help me out with all my toy problems.
Hope this helps
Posted on Jul 17, 2009
  • 29 Answers
SOURCE: Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Posted on Apr 20, 2010
  • 3 Answers
SOURCE: where is the battery located
Ours has the battery behind the front bumper. There are tabs on either side in wheel wells to release the front end panel and it pivots downward to access the battery compartment.
Posted on Sep 04, 2010
How do I get the piston to come up so I can attach it to the dump bed?
usually there is a red handle that you pull to release the piston
Nov 06, 2015 | Peg Perego John Deere Gator XUV 550...
How to remove motor from john deere gator power wheels
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels and axle
4. remove the red pin at the front of the dump bed
5. remove the two black pins at the rear of the dump bed
6. remove the dump bed
7. lift the green plastic cover off
8. remove the two screws that hold the gearbox and motor to the body
9. remove the gearbox and motor assembly
10. remove the two screws that hold the motor to the gearbox
May 19, 2014 | Peg Perego John Deere Gator HPX Ride on...
How to replace the tires on a Deere Gator
Nov 29, 2012 | Peg Perego John Deere Gator HPX Ride on...
How to connect a disconnect motor on a john deere
1. remove the red pin at the front of the dump bed
2. remove the two black pins at the rear of the dump bed
3. remove the dump bed
4. lift the green plastic cover off
Oct 23, 2012 | Peg Perego John Deere Gator HPX Ride on...
you probably have a disconnected motor, follow the steps below and check the motors to make sure they are connected
Oct 19, 2012 | Peg Perego John Deere Gator HPX Ride on...
How to remove bed
Jul 04, 2012 | Peg Perego John Deere Gator HPX Ride on...
How do i change the wheel motor on a peg perego gator?
remove the center cap of one of both of the rear wheels, then use a 13mm wrench on each side and loosen the botls then pull the tires and axle out, then remove the red plastic pin at the front of the dump bed nad the two black plastic pins at the rear of the dump bed, then lift up the green plastic piece and this will reveal the motors and gearboxes, you'll have to remove the two screws that secure the gearboxes to the frame and the wires that are connected to the motor, then remove the two screws that hold the motor to the gear box, then do this in the opposite order to reassemble
May 10, 2011 | Peg Perego John Deere Gator HPX Ride on...
How do you get to the two motors?
Remove the dump bed, then the seats, on the frame of the gator that was under the bed will lift up. there you will see both motors and wires
Feb 19, 2011 | Peg Perego John Deere Gator HPX Ride on...
Can't get the motor off to replace it, how do I remove the motor?
You take rear wheels off, then remove the rear axle.
There are 2 black hinge pins that hold the dump bed on. You need to remove those to get access to the motors.
I got help with my grandkids peg perego gator model at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
they repair these items and were really helpfull and patient...even with me:)
I hope this helps
Mar 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
Replace parts on ride-on toys
The little tikes gearbox and the peg perego gator gearbox are located in the same area.
The seat comes off the hummer which will expose the motors.
Then you take off the push nuts on the axle which holds the wheels on.
The peg perego gator gearbox is shown by taking off the two black hinge pins on the dump bed in the back.
Then carefully pull the green plastic cover off and that is under the dump bed. Now you can take off the axle and remove the motors and gearboxes.
Important note: You will have a cross shape gearbox or a pentagon shape gearbox. Make sure you notice them before you order! I made the mistake and ordered the wrong gearbox.
You can purchase these at this website I found
I get all my parts from this site. They are easy to work with and know what they are talking about on the phone.
Hope This Helps
May 26, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Logo
66 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
