Question about Spirit Exercise & Fitness
Dyaco z10 treadmill
Deck stops rolling after about 4 or 5 seconds
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: Optio Z10 beeps 4 times and shuts itself off 3-4
Your problem may be due to a weak/worn out battery or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your battery may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 04, 2009
aviral_srms
  • 1216 Answers
SOURCE: treadmill model 909 made by
surely there is some problem in the belt.
One of the ways to extend the life of your treadmill is to keep it clean and dust-free. Dirt and dust build-up, especially between the belt and the deck of your treadmill can cause excessive belt-deck friction. This in turn, can damage your electronics and even your motor.
You can check for excessive belt-deck friction by setting your treadmill around 4 MPH and walking on it. Press the stop button (or pull the emergency stop switch). You should have to take a few steps before the belt stops - if it stops suddenly there is probably a high friction problem.
Excessive belt-deck friction can also cause motor to stall or sound labored so again, keep your belt and deck free from dust and dirct and look out if this is a problem
Posted on Jan 26, 2011
Dyaco treadmill model 909
Please RUN the software calibration for easy diagnostic and fix it.
Go under the HOOD cover motor and see the steps. God bless you
Oct 10, 2013 | Exercise & Fitness
Contiually beeping, when started it stops a few seconds later
LUBE the deck belt+ roller bearing too. see the video and proceed according. If the problem persist after you lube , time to change the deck belt board complete.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack T7 si Treadmill
My t7 si is beeping continually and starts for a few seconds and stops
lube the deck belt+rollers bearing . If the problem persist, time to change the deck belt board complete.
God bless you
I have a Reebok Competitor RT8.0 treadmill less than 2 years old. Consistently, every 4 minutes and 10 seconds it will stop & then in a few seconds resume the same speed? I have replaced the...
this happens to do the lack of maintenance schedule, and the machine shut down, for to protect the electronic system.
LUBE inmediately the DECK belt, maybe you have a WORN deck belt, time to replace the deck belt.
Try again, and test it
God bless you
Oct 15, 2012 | Reebok Exercise & Fitness
Belt moves for split second then stops
1= Not rexactly, however you must LUBE the deck belt, this a problem because of lack of maintenance, probably a deck worn, this cause enough friction shut down the machine for protection electronic.
2)LUBE the rollers bearing.3)test the input voltage motor, if there are the motor need repair.4) measure the output voltage board, if there are NOT voltage, the board is faulty, see my personal TIPS, and see the block diagram. RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jul 09, 2012 | Nordic Track NordicTrack A2350 Pro...
My treadmill start and about 5 seconds it shows L5 and stop
Lube inmediately the deck belt, the shut down is for to protect the electronic system.maybe you have deck worn.
2) Lube the rollers bearing very well
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
May 09, 2012 | Exercise & Fitness
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Stops while in motion
May 01, 2010 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
Top Spirit Exercise & Fitness Experts
Mister G
Mister G
Level 1 Expert
Richard Warren
Richard Warren
greg kinsley
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
