Question about YouTube Computers & Internet
Youtubechannellist? List of channels?
    Top Expert:
  • YouTube Master
  • 14,161 Answers
Posted on Nov 29, 2015
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
Apr 24, 2017 | Samsung SyncMaster Televison & Video
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Channel lock is stuck on
May 28, 2011 | Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I just purchased the RCA model L32HD31R. Everything works fine except that I can't remove the analog channels from the list. I get my signal OTA so no cable or sat issues. I go into the List Menu and they...
I had the same problem and finally sloved it. You have to leave the input channels ( Vid1, Vid2, SVid, Cmpt, HDMI, etc ) in the In Channel List. So push the INPUT button, go to VID1, press Menu, go down to List & Labels then check In Channel list. Do this for all the inputs and then run your Channel search again. I hope this works for you. It did for me.
Jun 20, 2009 | RCA L32HD31 32 in. LCD HDTV
Channel selection
you may have to manually create your list. first make a list on paper of the channels that you want and proceed from there. somewhere in the menu there should be a place to do this. be patient, take notes about what you are trying and good luck.
Mar 24, 2008 | Televison & Video
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Computers & Internet Logo
24 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
