Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Jandy lite 2 leaking water on left front side
We opened the pool yesterday and the water heater starting leaking today. You can hear the air coming out of the front left corner when the pump turns off. Is it hard to take the heat exchanger off to find the leak? Can I fix this myself?
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Leaking heat exchange need new one
Posted on Apr 30, 2015
2 Suggested Answers
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
Why would water come out of the air blower on my pentair master temp 400
take off top[ and see if coming from heat exchange or pressure switch leaking
Jun 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Hi I have a Jandy Lite 2 pool heater model # LJ250NB and it will not light a code is coming up FL 0. I had info on the screen until I put a jumper wire on it and now I am getting nothing on the screen....
what did you attempt to jump??? no pwer on screen is usually a problem with secondary side of transformer. FLO has nothing to do with that. you prolly blew the transformer. FLO is an open safety within the circuit
Jul 29, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Heater will not come on; water is not circulating through heater
if no water is going through heater open return valve if you have a bypass only open half way see if that works or I need more info
Jun 09, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
My Laars lite 2 won't turn on. I hear clicking noise three times in a row, then it stops completely. What should I check first then second?
check water pressure switch and copper tube could be clogged or pressure switch not opening all the way also check wires to pressure switch could be loose
Oct 09, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Bubbles coming out of jets
Only one way to get bubbles and that is by introducing air into the stream most likely there is a leak in the plumbing this kind of leak only leaks air when there is suction. if you are losing no water then you have a suction side leak. WHich is strange because the heatr is not on the suction side.
Jan 01, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater leakage
Rob Cox
POOLCENTER.com
Jan 23, 2009 | Jandy Digital Lite2 Lj325 Btu Heater,...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
193 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
