G2600VH...my washer seems to be locked up with pressure which is locking the flywheel. The gun trigger no longer releases the water pressure, and I don't know how to safely relieve the pressure. I
Your pressure washer is equipped with a "unloader valve". This is the device that routes the water into a by-pass loop when you release the trigger. Something has gone wrong inside causing the valve to not spring into the unload position. You can take it apart and see if you can discover what is going on. The most likely thing is that a bit of water still in it froze this winter and destroyed either replaceable seals or distorted the valve body (which is not repairable). On these little homeowner pressure washers, the best place to get parts is usually through the owners manual that came with it, or Karcher may have a web site set up for this. Also there is the possible resource of a pressure washer distibutor, which you would find in the yellow pages. They usually concentrate on commercial pressure washing equipment, but sometimes getting parts or pumps through them may be easier.
