Question about Weather King 10AJA4201AH Air Conditioner
Not cooling I have a 10AJA4201 and it froze over the other day and I let it defrost and turned it back on. Now it won't keep up and runs constant. I have thermostat set at 73 and it won't get below 76. Heat of the day it goes above 80.
    Problem Solver:
  • 19 Answers
Check the evap(indoor coil) if its clean and there is not an airflow issue,make sure the out door unit shuts off when the indoor fan is not running .if all is good you may have to place a service call and have the refridgerant levels checked
Posted on Jun 23, 2009
  • 79 Answers
1st thing to check after you have turned on the unit for say 45 minutes is the larger line coming out of the house to the outside condensing unit. If that line is not sweating on a 40% or higher humid day, your unit is not fully charged with refrigerant, keep in mind also that your outside unit must be able to move air through the coil. If the coil is dirty, turn off the outside electrical box, and wash it down with your water hose till it sparkles, then wait until it drys, turn on the power, and check the large copper line, this line must sweat, if not, the unit is low on refrigerant, and must be charged by a serviceman
Jenn-air refrigerator not freezing or making ice
Before you go crazy just defrost the unit over night and then turn it back on. Possible e that the evaporator froze up due to the open door..Let it stabilize for at least a day and then check to see if all is copacetic.
Sep 14, 2017 | Jenn-Air Refrigerators
Tip
How to fix a Refrigerator that Doesn?t Cool or Runs Constantly
If the refrigerator’s light works and you can hear the refrigerator running but it cools poorly or does not stop running, make sure nothing is blocking the passageway between the freezer and the refrigerator compartments. If airflow is restricted by, for example, a loaf of bread situated in front of the passageway, the refrigerator won’t get cold. Be aware that a refrigerator will tend to run longer when it’s full of food, the door is opened frequently, or the room temperature is hot.If your refrigerator runs without stopping, it may be low on refrigerant and cannot reach the low temperature that the cold control dial summons. More likely, it is a defrost problem in which a component in the automatic defrosting system is faulty. This could be a defrost heater, a defrost timer, or a defrost terminator.
Before you call a repairperson, do the following:
1) Determine whether the refrigerator section is being cooled. If you see frost at the top of a “frost-free” refrigerator even when the cold control is set low, it means the refrigerator probably has a full charge of refrigerant and it is the thermostat that is faulty or out of calibration.
2) Try turning the cold control both up and down. If the compressor doesn’t shut off, the cold control may be broken. Call a repairperson. During the repair, it is a good idea to have the defrost timer and heaters checked to ensure they are working correctly.
3) Look at the condenser coils, located at the bottom of the refrigerator (behind the kick plate) or, in some cases, at the back. These coils disperse heat from inside the refrigerator out into the room with the aid of a fan. If the coils are dirty, the refrigerator won’t operate efficiently. You must clean them regularly.
4) Make sure the drain line under the evaporator coils, which goes to a pan underneath, is not plugged up (water should drip into the pan when the refrigerator is defrosting).
5) To put off having the refrigerator repaired for a few days, you may be able to defrost it manually with a hair dryer—if you can access the cooling coils in the freezer section. Excessive moisture in the coils can turn into a frozen mass, reducing efficiency. Be very careful when using the hair dryer near a water source as there is a serious risk of electrical shock. Also be careful not to melt the plastic parts.
on Sep 02, 2010 | Refrigerators
Hi I have a GE model# DSS25KGRE BB fridge. The fridge runs constantly, meaning it cools until the coils get all frosted up. then the defrost heater kicks on and 'thaws' the coils. I have tried
OK, first check the condenser coils and fan to be sure they are free of lint and dirt buildup. Dirty coils will keep the unit from cooling correctly and the unit will run endlessly. Post back the results to me and we will take it from there.
Regards,
Richard Roth
http://appliancecafe.com
Nov 30, 2012 | Refrigerators
My Ge profile with freezer on the bottom is not cooling. The fridge is 60 f or 15 C. The coils are clean and frost free. There is some frost on the copper tube that is surrounded by a foam wrap where it...
It is froze up there is no cool air going to the bottom. sometimes one will do that. defrost timer did not work. or the heat coil is bad. unplug it for about 8 hours to let it throw. and see if that will fix it. If it runs ok for about 5 days and dose it again. it is not defrosting.
Sep 22, 2009 | GE Refrigerators
Freezer works, fridge does not,runs constant though
Try turning it off and defrost it for 48hrs with both doors open. Then turn it back on if it's still not colling the fridge then you need to check to see if the fan in the freezer goes at all. If it cools for a few days then goes warm again you may need a new D'frost element, D'stat or something else cheers
May 15, 2009 | Electrolux Refrigerators
Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Frigerator runs constanly till compresser gets to hot
Sounds like it might be the thermostat
sensor bulb is defective see if you can
turn the refrigerator off with the thermostat
the defrost heater is supposed to heat up
enough to open the defrost thermostat
Make sure the defrost timer works to
turn on lhe heater & turn off the defrost tstat
turn the power off and check the tstat & defrost
heater for continuity check to see if tstat open
and closes when you turn the knob,
if you remove the tstat you can check the
bulb in ice water and warm water aborv 40
to see if tstat cycles on and off
Nov 26, 2007 | Maytag MSD2650H Side by Side Refrigerator
Weather King 10AJA4201AH Air Conditioner Logo
132 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
