Question about Sanyo Televison & Video
Sanyo model ds25030 channel search??
I'm hooked direct to a coax with basic cable. No box. During channel search it gets channels 2-47 and 94-99. I hooked another tv up and it gets all channels. I've seen others with same problem but with no real solutions. Can somebody figure this out once and for all?
techman
  • 3130 Answers
SOURCE: Concierge series 25" wont stay on channel 3
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
Posted on Jul 30, 2006
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Posted on Mar 31, 2008
  • 520 Answers
SOURCE: how to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
Posted on May 13, 2008
SOURCE: orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Posted on Jun 09, 2008
Slapnuts1975
  • 51 Answers
SOURCE: program an old sanyo tv
You need to go into the menu and set it for cable insted of air/tv. The television is only getting the 2 - 13 because on that setting, its as high as it goes.
Posted on May 20, 2009
Getting no cable channels.
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Feb 04, 2017 | Sanyo Televison & Video
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
Volume disappears on certain channels
if you get sound on some channels and not on others it's
not your tv. do you have your cable box or what ever, hooked up to tv through a caoxal cable or through audio video jacks .some shows only have right or left audio not both if you use a coax from box to tv try av wires insted
Oct 01, 2013 | Sanyo Televison & Video
Hooking sayyo tv to directv
Not sure if I understand what is happening here but if set on channel 4 the connection for the direct TV would have to be to the coax fitting on the rear of the set.
For the audio/video inputs on the rear or side it would have to be the same ones coming out of the direct TV box to one of the same but inputs on the rear--Audio/video are one connection and coax for channel four is a different one.
Dec 22, 2012 | Televison & Video
How do you hook up to cable, comcast
If no box, then directly to the coax connector on the rear of the set, if using a box set to the channel the box is set for (usually 3 or 4) and output coax from box the coax fitting on rear of set.
Leave set on three and power box and change channels with the box.
Dec 17, 2012 | Toshiba 50H82 50" Rear Projection...
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a JVC tv model AV 27495. I hooked it to the cable with the cable cord. I can only get cable 2 channel. I can't access any channels. What do I need to hook into the cable? Do I need a box since...
Yes, with the Direct TV box it did all the tuning and your TV had only to be on one channel, normally ch 3 or ch 4. Now that it is not there any more your TV tuner must do the work. You now will have to tell the TV to search for channels. Use your remote and TV menu to do this. You will be able when the search is complete to see some of the cable channels but other premium cable channels you won't be able to see without a cable box.
Sep 12, 2010 | JVC Televison & Video
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
To hook cable to tv
tke the coax cable coming out of your cable box and connect into the coax connector on
your tv.put the tv on channel 3 and change channels with the cable box.if you do not have a cable box run thcable from the wall into your
tv and auto-program the tv.
Jul 28, 2009 | Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
156 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
