Question about Konica Minolta Office Equipment & Supplies
I have problem code c3501 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
On what model machine?????
Posted on Dec 29, 2015
Bizhub C7000 service call no c3501 how to solve this problem
Hi this is Alex Walker expert to help you for this Issue call +1(404)981-1535 I will be glad to assist you Thanks
Jan 04, 2016 | Office Equipment & Supplies
How can I enter service mode on a Konica C7000? It is in fault mode with a code of C3501
This reset procedures reset the copier fuser the hot part if the code comes back aftyer procedure DO NOT DO AGAIN IT CAN CATCH ON FIRE RUINING A PERFECTLY GOOD DAY!!!!!!!!!!! Get a tech out to look at it
1. Be sure that the ordinary operation screen *1 is displayed.
Press [Utility/Counter] button.
2. "Utility screen"
On the Operation panel, press the following buttons.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
When the CE password has been set, entering the password is required to enter the service mode.
3. "Service Mode Menu screen"
The service mode appears.
*1 Default is [MACHINE] screen.
go to
03 System Setting
• 01 Software DIPSW Setting
set the DIPSW 3-1 to 0.
why you do it once then get a tech out to look at it. DIPSW3-1 is set to 0 before defective parts are fixed, it may cause fire
Jan 04, 2016 | Konica Minolta bizhub Office Equipment &...
How do I prevent envelopes from getting creased on a Ricoh MP c3500?
Hopefully you are using the bypass when printing them. Creasing is only caused by two things. Moisture in the paper and uneven fusing. Make sure when you are printing them you select thick 2 in the printer properties pull down menu. If the problem continues switch the feed direction and possibly the brand of envelopes. The same thing applies to printing labels (the thick 2 setting will provide the necessary heat to properly fuse the toner). But when copying, push the # key and select thick paper from the menu there.
Nov 21, 2014 | Ricoh Aficio MP C3501 Multifunction Color...
Konica c 3501
what model do you have???????
May 09, 2014 | Konica Minolta Office Equipment & Supplies
I want to buy a printer
Buy mp aficio c3501/2500
or possimly call +233243494871
Jan 27, 2014 | Gestetner Office Equipment & Supplies
Hy how are u.i hav a problem with ricoh mp c3501 copy machine.its showing error at screen SC582 if any body know about this error how to soulv it so plz help me am waiting.
Mr Aziz, the machine tell you the termistor had to be replaced located at the back of the fuser unit.After replaced it ,you have to reset the maschine in SP mode.....good day
Sep 01, 2013 | Ricoh Aficio MP C3501 Multifunction Color...
My konica minolita bizhub 501 is showing the error code C3501. How do I fix this?
if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1.
Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.)
2.Turn main power switch ON while pressing the Utility/Counter key.
3.Touch [Trouble Reset].
4.Check to make sure that [OK] is displayed and the it has been reset.
5.After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Oct 12, 2012 | Konica Minolta Bizhub 501 Copier
Hi I need PHILIPS P568 IMEI 351265412565412 unlocking codes.... please help me.
Codes for imei 351265412565412, model Philips P568 Unlocking codes: Code for NCKKN is : **00012*39094694# Code for NSCKN is : **00022*35077294# Code for SPCKS is : **00032*36089094# Code for CKCCK is : **00042*37037294# Code for PCKKP is : **00052*33054694# Code for XXXXX is : **00062*37035294# Code for XXXXX is : **00072*33775294#
Repair codes: Code for NCKKN is : **00013*43714762# Code for NSCKN is : **00023*43070742# Code for SPCKS is : **00033*43251752# Code for CKCCK is : **00043*43072702# Code for PCKKP is : **00053*43718722# Code for XXXXX is : **00063*43872702# Code for XXXXX is : **00073*43878442#
New Algo Codes Unlocking codes: Code for NCKKN is : **00012*7563374371217567# Code for NSCKN is : **00022*7161634379412367# Code for SPCKS is : **00032*7262814378202967# Code for CKCCK is : **00042*7367634371472367# Code for PCKKP is : **00052*7969374375277567# Code for XXXXX is : **00062*7367434371470367# Code for XXXXX is : **00072*7931434377110367#
Repair codes: Code for NCKKN is : **00013*2159969789537257# Code for NSCKN is : **00023*2185567789015457# Code for SPCKS is : **00033*2103668789074247# Code for CKCCK is : **00043*2185763789017417# Code for PCKKP is : **00053*2159365789531217# Code for XXXXX is : **00063*2165763789817417# Code for XXXXX is : **00073*2165337789813157#
May 17, 2010 | Belkin Cameras
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
