Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet quites mowing when it gets hot - Cub Cadet Street Sign- tractor lawn riding mower parts
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Need to have valve jopb done bad valkv
Posted on Dec 17, 2014
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
  • 1111 Answers
SOURCE: Engine will not start
you have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Posted on Jun 17, 2009
SOURCE: I own a cub cadet LT1042. I started mowing tonight
Replace your drive belt
Posted on Jun 30, 2009
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Posted on Jul 29, 2009
Was mowing-blades just quit turning-pto will not engage
Belt has broken, or jumped off the pulley, or jumped off the belt tensioner. Look at your deck and go from there. You may have to remove your deck to get to the belts under there cvers but you will see your problem.
Jul 03, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
The pto quits working after a few minutes of mowing. After sitting for awhile it will work again, but just for a few minutes again.
Check the drive belt , it is probably worn and polished, it will grip a little when cool but will slip as soon as it gets hot.
Aug 22, 2010 | Cub Cadet Garden
Cub cadet oil changing? Every when?
general rule is to change oil every 50 hrs and even more frequently if used in hot / dusty conditions or with heavy loads , check oil before each mow , and clean air filter every 25 hr
change oil filter every 2nd oil change at least
cheers paul
Aug 02, 2010 | Cub Cadet Garden
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet zero turn mower quits mowing, service center says clutch is fine but can't find anything wrong. Put 30 amp fuses in and they will blow after about 30 minutes of mowing. Any suggestions
when the fuse blows check for hot wires it seems to have a short somewhere hardist thing to find. look for naked spots on wires or pinched wires .
Oct 21, 2009 | Garden
REMOVE PARKING BRAKE ENGINE STALLS
i have a cub cadet 2130 2000 seris but it quits when i rekwase the brake pedal
May 03, 2009 | Oregon Scientific Oregon Gator Mulcher...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
