Question about Fisher Studio Standard
Top came off with belt how do i repair?' - Fisher Studio Standard
Replace a Tape Deck Belt
. Remove top lid (4 screws on the side)
2. remove the back plastic mount on the mechanics (2 pink long screws on the top). The bottom are two plastic hook lock. The mount pulls back and the belt and pulleys are exposed. NOTE: It is the mount you are removing, not the tape deck itself.
Jul 05, 2008 | Audio Players & Recorders
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
My washing machine has a broken drive belt!
Not a good model number, so I can't be positive on this. All whirlpool top load washers built in the last 25 years are no longer belt driven, they are direct drive, Broken drive coupling is a very common problem. If you have a wp washer older than 25 years with a drive belt, I don't recommend you repair it as there are a number of major repairs at the same time. Outer tub major corrosion, leaks small amounts of water onto the base plate and then into the wig-wag assembly(electrical shock hazard), main bearing-basket drive assembly, water pump bearings and seal fail(this is usually what burns out the belt. Ect, ect. For Repair manuals try Reliable Parts Co. at 1800-666-0313 Good Luck, Appliance Specialists
Dec 17, 2009 | Whirlpool Washing Machines
Belt repair kenmore model 57612690 belt 20-5285
You can get the belt you need here:
Kenmore 20-5285 Belt
Replacing the belt is quite simple. First, push inward on each side of the light cover on top of the power nozzle and it will lift off. You will then see (2) access screws. Remove the screws and then the top cover can be removed from the base of the power nozzle. You can then remove the old belt and replace it with a new one. Hope this helps!
Dec 07, 2009 | Vacuums
Looking for a belt for G.E tumble dryer, model no: TL22PG. cant see code on belt as it is shredded.
take you model number to repair shop they will know
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Dryers
Stopped tumbling
First make sure your belt is broken.
Take a putty knife or a old CD and insert it between the top and the front panel about 2 inches in from the sides where the top and front come together.
Push the clips towards the back of the machine while pulling up on the top.
Once it is open you can tell if the belt is broken or not.
It you see no belt around the drum it is broken.
If you see a belt around the drum pull on it carefully.
If it does not come loose it is not broken.
After you do this, let me know the result.
We will then move on to step #2.
Mar 15, 2009 | Maytag PYE2200 Dryer
Repair book for Belt replacement Roper REX5634PQO
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Roper REX5635E Dryer
AMana top washer LWA 65/a
there is no belt its a coupler between the motor and the transmission
Dec 07, 2007 | Amana NAV5805A Top Load Washer
Belt repair
if im right on the top where you change the settings for your carpet there should be 2 screws take th e whole top cover off theres a plastic cover for the belt take that off and the rest should be self explanitory
Nov 26, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
Fisher Studio Standard Logo
18 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
