Question about Dishwashers
What do rapidly flashing 3h & 6h lights mean Hotpoint SDL510
Does not start, does not fill. everything goes off except 3h & 6h lights
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
57 varieties
  • 1653 Answers
SOURCE: when i start my dishwasher it sounds like it is
This indicates an error with the pressure switch and indicates that it is jammed on full. First try switching off ther AC power to the washer and letting it stand for 30 minutes. Then switch back on the AC power and see if the error is still present. If it is then the pressure switch will need to be replaced. The pressure switch is how the machine determines how much water there is in the machine and if the switch is indicating the machine is full it will automatically pump and empty as soon as new water enters the machine.
Posted on Nov 10, 2009
SOURCE: My dishwasher will not start. The LED's are all
Try plugging it in to a different power point or check the electrical connections.
Posted on Nov 01, 2010
Daniel S
  • 4323 Answers
SOURCE: lights 4 & 6 flashing
Hi
Flashing 4 and 6 lights means that the heating element is bad and should be replaced. Sometimes the unit will start a wash and then cut out when it needs hot water as it finds that the element is not working. Sorry for the bad news, but this is the only recommended repair. Hope this helps...please post back for further assistance.
Daniel
Posted on May 06, 2011
  • 3247 Answers
SOURCE: Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Posted on Nov 06, 2012
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Dishwashers Logo
206 people viewed this question
Top Dishwashers Experts
