Question about Dishwashers
What does rapid flashing 3h and 6h lights mean on Hotpoint SDL510 Dishwasher?
Does not start, does not fill. after a while 3h & 6h lights come on everything else goes off
Poohs
  • 4 Answers
SOURCE: BF162 Hotpoint intergrated dishwasher
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
SOURCE: hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Posted on Sep 21, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint dwt10 not working rinse aid light flashing
I have DWT10P dishwasher.It is displaying two rapidly fashing E lights (Fast & Delicate )wash cycle.Can you tell me what its mean?
Mar 24, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Hotpoint dishwasher model BFI62
water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Dec 23, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
NOT WORKING FDW20p What does it mean
Hold the start key down and it should re-set . Please Rate This ! Thanx!!
Apr 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
Owen Barnes
