Question about Craftsman Garden
My Craftsman edger model#316.791890 works for 10 minutes. Once it stops I can't get it restarted for 20 minutes. New spark plug, just got it back from the repair shop where they cleaned it and change a fuel line. Need help. Thanks!
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
  • 10865 Answers
SOURCE: craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
Posted on May 20, 2009
  • 69 Answers
SOURCE: craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
Posted on May 27, 2009
jcameo7270
  • 675 Answers
SOURCE: I have a Craftsman eagle
You may need to have a rebuild kit put oin the carb...or you can try cleaning the carb out....it may have "varnished gas" that may have blocked one of the orifices...I use a torch tip cleaner to clean out ports and needle jets as well as soaking...also have found that seafoam works well as a carb soak...there is also the possibility there is no spark(bad coil), the lead that shuts down the engine is always grounded(which will result in no spark). Try sparying a little Ether into the carb to see if it will kick over...this will ensure everything electrical is ok
Posted on Feb 09, 2011
#1 Taper
  • 1040 Answers
SOURCE: My weed eater gti 15t runs great for about 10-20
Try my Tip on this subject; you won't believe it!!
www.fixya.com/support/r6081786-trimmer_weed_eater_only_runs_10_15
Jim
Posted on Aug 07, 2011
Was mowing the lawn about 20 minutes then mower stopped. It is a craftsman platinum 7.25
sounds like the spark plug may be fouled or the fuel filter or carburetor is dirty.
Sep 17, 2016 | Craftsman Garden
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
My Craftsman Weedwacker, (Model # 358.791010 ) does not start. originally it took about 5 - 10 minutes to start and once it was running, I'd hit the switch from "START" to "RUN" and...
Sounds like a carb problem. You may need to rebuild it. Check to see if your fuel lines inside the tank have rotted. Common problem on Craftsman.
Nov 01, 2010 | Craftsman 25cc Gas Line Trimmer
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
May 20, 2009 | Garden
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2002 craftsman 23 hp kohler pro series stalls and wont restart
try playing with the throttle adjustment or it could be a saftey feature malfunction, like the seat shutoff for example.
Feb 25, 2009 | Craftsman Garden
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
